I’m using an Ameridroid N2+ with Home Assistant OS core-2023.6.3 and Node-RED.
I’m stuck on where the Write File node will locate a file. I know I specify the path in the node properties but I’m not sure where in the file system I can access.
I have a process in Home Assistant to create a file using the Notify Service and my file is locating to the /config/www directory. If I could write to that directory it would be good but when I use that path I’m not getting a file.
