schnu240
(Schnu240)
February 16, 2025, 10:43am
1
i have actual the need to write the values from a Datetime Helper into another Datetime Helper but it does not work right now.
metadata: {}
time: "09:30:00"
entity_id: input_datetime.kg_h_kinderzimmer_wecker
action: input_datetime.set_datetime
I tried to exchange the “data” to an input_datetime but I am not allowed to safe this script. Is this even possible to write a Datetime into a Datetime?
Of course it is possible, but you cannot just enter an entity ID as the data for the action – you need to write a template that gets the state of the other input_datetime, and if both of them are not set to the same mode (date & time, time only or date only) then you may also need to do some data manipulation.
- action: input_datetime.set_datetime
entity_id: input_datetime.target_datetime_helper
datetime: "{{ states('input_datetime.source_datetime_helper') }}"
schnu240
(Schnu240)
February 16, 2025, 11:02am
3
That was fast I will check it directly thank you
schnu240
(Schnu240)
February 16, 2025, 11:06am
4
It let me save the automation but by triggering it I get this error:
metadata: {}
datetime: "{{ states('input_datetime.kg_h_kinderzimmer_wecker_wochentag') }}"
If both input_datetime helpers are set to time only, then the data input should be time (rather than datetime as in my example).
schnu240
(Schnu240)
February 16, 2025, 3:48pm
6
Perfect. It seems to be working right now. I will test now the complete automation.
Edit: Automation worked exactly as expected. Thank you very much @Mayhem_SWE for your fast and productive support.
