Dimumal
(Dimu)
November 19, 2023, 9:47am
1
I have connected my SRNE inverter to Home Assistant through ESPHome. It can read the values & display in my dashboard.
Now what I want to do is to change the inverter parameters through Home Assistant and/or automation. (ex. change the Output priority from SBU to UTI)
There’s an registry entry with read/write for this setting as below.
It correctly read the current output priority setting as 2 (which is for SBU)
Is it possible to write the value back to inverter through Home Assistant so that I can change the output priority? Since I’m with 0 knowledge in coding, can someone please help me with this?
zoogara
(Daryl)
November 20, 2023, 3:15am
2
You probably need to have a read of this:
Then re-post your question with “Modbus” in the title, to catch the eye of the Modbus experts amongst us (I am not one).
Dimumal
(Dimu)
December 2, 2023, 12:15pm
4
User
esphome:
friendly_name: SRNE
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "+EMWnue33wLGXOUUcZdBgtEcWOJjQIPoN7E3WbVj2UA="
ota:
password: "27a70d64573b33d2dc248577739abfa5"
wifi:
ssid: !secret wifi_ssid
use_address: 192.168.1.16
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.1.16
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.1.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
uart:
tx_pin: 19
rx_pin: 18
baud_rate: 9600
stop_bits: 1
modbus:
flow_control_pin: 4
modbus_controller:
- id: srne1
address: 0x01
modbus_id: tdt1_modbus
setup_priority: -10
update_interval: 15000ms #data refresh rate
switch:
name: "Output Priority Switch"
turn_on_action:
- modbus.write_register:
address: 0xE204
value: 1
turn_off_action:
address: 0xE204
value: 0
- platform: modbus_controller
modbus_controller_id: srne1
name: "Output Priority" #name for HA
id: srne_output_priority #id for HA
register_type: holding
address: 0xE204 #register address
When I enter like this I get an error saying
switch.template: [source /config/esphome/srne.yaml:52]
platform: template
name: Output Priority Switch
turn_on_action:
Unable to find action with the name ‘modbus.write_register’.
address: 57860
value: 1
Please help
Hi Dimu,
Did you find a find a solution for this and are you able to set the Output priority of the inverter remotely now?
I am trying the same thing with a generic python modus script. I am able to configure the energy save mode (E20C) but all other RW parameters return a 0BH error (insufficient permissions) when I try to write to them. I noticed that the iPow Software from SRNE can’t set these either, also contacted their customer support with no success. There might an additional step required in order to acquire the permission.
Dimumal
(Dimu)
May 7, 2024, 2:26pm
6
No have not found a solution yet
