Hi Bouni, I would like to write some basic features. Only the options that can be set by the user, so not the settings after the installation code. In this way, the user can’t destroy anything.
Dear @Bouni, I have experienced a problem with the status of the heat pump since the mode has been set to cooling. The operational status parameter is ‘ID_WEB_WP_BZ_akt’. Thats works for the status Heating, hot water but when the pump is cooling that parameter says “No request”. I’m 100% sure that the pump is cooling. I can ensure that by watching the the temperatures in and out AND the status on the RBE that says cooling.
Are there more people with this problem or am I the only one?
I cannot very at the moment because mine is not yet set to cooling but I will do that in a few days (not at home at the moment).
As soon as I’ve done that, I’ll check what we can do to show the status while in cooling mode.
After hours of trying to make this beautiful component work I have go give up. Maybe somebody can help me? I’m running 0.89.2 in production and also tested it on 0.94.1. I downloaded the directory here https://github.com/Bouni/Home-Assistant-Luxtronik and copied it into my custom_components directory. I also copied the “all requirements” text file from Bouni’s repository into my configuration directory. Unfortunately both versions show me the following errors:
File “/srv/homeassistant/lib/python3.6/site-packages/homeassistant/setup.py”, line 154, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/home/hass/homeassistant/custom_components/luxtronik/init.py”, line 40, in setup
conf = config[DOMAIN]
KeyError: ‘luxtronik’
It looks like the setup of the component is not sucessfully, can you remove the custom component and start over? Line 40 is part of the initialization.
I removed the luxtronik folder in custom_components and replaced it by the folder that I downloaded from Bouni’s github site. I also configured the sensor + binary_sensor as per the example provided. Now the error message changes. When checking the configuration (in configuration validation), I immediately get the following message:
Platform not found: binary_sensor.luxtronik
Platform not found: sensor.luxtronik
When starting homeassistant, I get the following error in the log:
Unable to find platform luxtronik. Search path was limited to path of component: custom_components
I feel like I’m doing something terribly wrong, but what?
Guys, thanks for your help. Something amazing happened. After erasing my entire homeassistant database and restarting HASS, all of a sudden the component loaded as supposed. It works. Thanks!!!
With regards to ID_WEB_WP_BZ_akt not showing as cooling: I’ve got exactly that and therefore will probably switch to ID_WEB_HauptMenuStatus_Zeile3 for status monitoring. Will still have to see when these two differ.
In my previous scripted code I used ID_WEB_WP_BZ_akt by default for status, but when it was set to “no request” (5) I checked if ID_WEB_HauptMenuStatus_Zeile3 was set to 10 and then gave back the status value “cooling” instead of “no request”.
For some reason the pumps firmware never sets ID_WEB_WP_BZ_akt to “cooling” (7).
Sorry guys for not looking into this issue, I’m very busy at the moment.
If you take a look at the lookup table of the luxtronik module the heat pump should switch to cooling (value 7).
This knowledge comes from reverse engeneering the sources, but to be honest, it’s quite a mess.
So I would wonder if the value 7 is actually never used and they use other values for cooling.
I really need to reverse engeneer the AlphaApp to see what values are the best to use.
As of now I can say for sure that they use the same binary protocoll for the App if the phone is in the same network.
Damm good point. I’ve look into the AlphaApp and when I check the Cooling status, I also got the status ‘No request’. So that’s the explanation about this problem. I will contact my installer and importer (Nathan) about this problem.
