Not sure if this is useful to anyone but I’ve started by getting some support for Osram Lightify bulbs together. Don’t think it complies with criteria for a pull yet but I’m still working on it. Can be found here if anyone is at all interested. Would be nice to hear from anyone else using these if this came in useful for them:
I just grabbed one of these lights and its gateway. I can control it with the Lightify app, but I haven’t tried home assistant yet. Have you had luck with the code github repo you posted?
There’s been a firmware update recently that means the protocol is a little different so make sure you’re on the latest firmware.
Make sure lightify.py is in the site pacakges example: ./.local/lib/python3.4/site-packages/lightify.py
Make sure osramlightify.py is in the components directory: ./.local/lib/python3.4/site-packages/homeassistant/components/light/osramlightify.py
And make sure the following is in your configuration.yaml
light:
platform: osramlightify
host: “Lightify-XXXXXX.my.domain” (or use the IP address)
After you’ve done all of this, restart home assistant. And your light should show up. If it doesn’t try turning on debug and let me know if you see anything a miss and I’ll try and help out.
I’ve just made a little more progress. Using the lightify.py module in the following manner managed to turn the light on and off:
>>> import lightify
>>> l = lightify.Lightify('Lightify-XXXXXXXX.local')
>>> l.update_all_light_status()
>>> l.lights()
{NNNNNNNNNNNNNNNL: <lightify.Light at 0xHHHHHHHHHH>}
>>> a = l.lights()[NNNNNNNNNNNNNNNL]
>>> a.set_onoff(1)
>>> a.set_onoff(0)
Actually, after restarting Home Assistant it works!
There must have been some state synchronization issue somewhere along the line. When I first started this morning the light wasn’t even responding to the Osram app and I was getting stack traces frome Home Assistant when trying to turn the light off. The root cause may have been the torchier lamp I had the bulb plugged into, it has a turn knob with three dim settings. I imagine the bulb doesn’t work well in the lower dim levels and there’s no way of knowing what state the knob is in (without switching bulbs).
Now with it working I may go back to Lowes to get more of these bulbs since they are relatively cheap $17USD.
I was just starting to develop my own Lightify support for home assistant, when I came across your post. Thank you for sharing your work! Andreas Neumeier provides the Library via pip. May be you could use this instead of adding the library by hand.
Thanks for the heads up, I maybe doing something wrong but I don’t think the lib is Python 3 friendly.
" string = string + data
TypeError: Can’t convert ‘bytes’ object to str implicitly"
I remember bumping into this and another error because of changes between Python 2 and 3 which I fixed in my fork, so unless this gets fixed I think it means it’s a no go. Unless some one else can chime in with some useful information?
I’ve added a pull request for Andreas Neumeier’s fork here: https://github.com/aneumeier/python-lightify/pull/1 which should solve the python3 issues and also treat cases when luminosity is increased and the state is off and when luminosity is set to 0 and the state is on.
From what I see there is no need for set_onoff method as we can use set_luminance to turn the bulb on and off, this also allows us to use fade transitions for on/off.
There are still some quirks with the brightness, but haven’t had time to fix it and also, I only have one RGBW light to play with, that means that non RGBW bulbs and flexlight strips might not work at all.
File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 809, in job_handler
func(arg)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/event.py", line 179, in pattern_time_change_listener
action(now)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 191, in _update_entity_states
entity.update_ha_state(True)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 145, in update_ha_state
self.update()
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/light/osramlightify.py", line 165, in update
self.update_lights(no_throttle=True)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/util/__init__.py", line 289, in wrapper
result = method(*args, **kwargs)
File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/light/osramlightify.py", line 67, in update_lights
bridge.update_all_light_status()
File "/home/hass/.homeassistant/deps/lightify/__init__.py", line 430, in update_all_light_status
data = self.build_all_light_status(1)
File "/home/hass/.homeassistant/deps/lightify/__init__.py", line 320, in build_all_light_status
struct.pack("<B", flag)
File "/home/hass/.homeassistant/deps/lightify/__init__.py", line 232, in build_global_command
self.next_seq()
struct.error: ubyte format requires 0 <= number <= 255
Anyone else found this? I haven’t had a proper chance to investigate my self yet.
Yeah, I’ve noticed the issue too. My guess is (and it’s just a guess now, as I didn’t have time to debug) that the connection fails at some point (usually a few hours after starting up HASS) and there is no mechanism for reconnecting(restarting hass and reinitializing the lightify bridge connection fixes the issue)
I was thinking of the lightify library and the way it is designed as it creates the connection when Lightify is instantiated, wouldn’t it be better if a connection is made each time you attempt to change/update/get state of the bulbs and then the socket be closed.
I don’t know much about network programming, but it would seem more efficient. I’d appreciate input here from someone that is more experienced in this matter.
I ended up disabling the following until I get round to having a proper look. This puts me roughly at the behavior and state of my previous code. It works fairly well since the update doesn’t change much as I don’t usually introduce new bulbs without a restart anyway.
def update(self):
"""Synchronize state with bridge."""
I was previously trying to do something along the lines of opening and closing the socket in lightify.py at every operation (read or write). Or at least having a catch condition that if it tries and can’t write it attempts to re-establish the connection. This was a problem I saw in my original code but as it happened so infrequently I just ended up having a Nagios job restart HASS until I get round to fixing it.
I’m not sure if there’s a more elegant way than try to read / write, fail, retry connection if that doesn’t work then generate an exception?
I’ve made some changes to the lightify library that should improve things. Still inneficient as it will re-connect if it fails to send data or receive, but it should work, at least it works if I unplug the bridge and plug it again without restarting hass.
The file is here: https://gist.github.com/olimpiurob/673659c93f5750a92498397333ddc775 and you just have to copy it over the old lightify’s __init__.py file, probably located in /usr/local/lib/python3.4/site-packages/lightify/. This should be further improved.
If it works, I guess I’ll just make another pull request as it is, as I seriously lack free time to properly fix this.
This is due to: self.next_seq() incriminating beyond 255. I’m not sure how the sequence number impacts things at a protocol level, I need to do some more research.
I think some of the reconnect code added by Olimpiu Rob is creating this, I’ve not had the same happen to me but for some reason it’s constantly reconnecting to your gateway. I’ve noticed where he’s refactored / rewritten some of my original code he’s introduced some (personally) undesirable behavior (light luminosity not being preserved between on off states of the light) so I’ll need to look into that. I’ve not been able to re-create the disconnecting bug my self yet but my setup usually runs a few weeks / months before giving trouble (The gateway is fairly close to the wifi AP so think that helps).
Can you check and if available update your firmware via the official application? Long shot but never hurts to be on the latest version.
I haven’t seen the constant reconnect since last restart. I’m on the latest firmware, I just updated when I got a replacement unit (my first bulb died after a few weeks…). It might be related to the fact that I removed the bulb, and placed it in another lamp yesterday (without touching he gateway)…not sure. There is no signal issue for sure, my apt is too small for that
I’ve also noticed that it doesn’t keep the dim state, like you mention… Sometimes the toggle also jumps back to the current state. If I turn it on, it just jumps back to off (and does nothing). On a second try, it works. This may be an issue with lightify, as I’ve seen that sometimes in the app as well.
