Saiert
1
My Zigbee radio-controlled socket is displaying the wrong amperage. Is there any way I can correct or adjust this manually?
francisp
(Francis)
2
It would help if you told us what socket, and if you are using ZHA, Zigbee2MQTT, Deconz or a Tuya Zigbee bridge.
Saiert
3
I use ZHA with a Sonos Zigbee Stick V3
francisp
(Francis)
4
You probably need a custom quirk
Hedda
(Hedda)
5
Your device will need a new custom ZHA Device Handler (also known as ZHA Quirk) so submit a device support request, see → https://www.home-assistant.io/integrations/zha/#how-to-add-support-for-new-and-unsupported-devices
