just started to implement BOSE soundtouch into my config but I still receive error while starting the server …
do anyone has idea what I have to change?
thx
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 51.05
longitude: 13.75
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 117
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Berlin
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
http:
# Uncomment this to add a password (recommended!)
#api_password:
# Uncomment this if you are using SSL or running in Docker etc
# base_url: example.duckdns.org:8123
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather Prediction
platform: yr
# Text to speech
tts:
platform: google
media_player:
- platform: soundtouch
host: 192.168.178.39
port: 8090
name: Soundtouch Living Room
- platform: samsungtv
host: 192.168.178.29
- service: media_player.play_media
entity_id: media_player.soundtouch_living_room
media_content_id: 1..6
media_content_type: PLAYLIST
Can you post your config so the formatting is maintained? It is very important for the config that the formatting is correct and it cannot be checked in what you posted above. See the following link for how to post your config and maintain formatting.
homeassistant:
latitude: 51.05
longitude: 13.75
elevation: 117
unit_system: metric
introduction:
frontend:
http:
#api_password:
updater:
discovery:
conversation:
history:
logbook:
# Track the sun
sun:
platform: yr
# Text to speech
tts:
platform: google
media_player:
port: 8090
17-01-25 08:17:09 homeassistant.bootstrap: Invalid config for [media_player]: required key not provided @ data[‘platform’]. Got None. (See C:\Users\id\AppData\Roaming.homeassistant\configuration.yaml, line 53). Please check the docs at https://home-assistant.io/components/media_player/
This cannot go under media player, but underneath a script or automation. Therein lies your problem. Since you have it underneath a media player, the media player service expects you to put a required key ‘platform’ (as described in the log).
Thx I know what you mean. So I put the service line underneath an automation
automation:
alias: Play Music
entity_id: media_player.speisesaal
media_content_id: 1…6
still not working. I also tried this:
scipt:
But before you start with automation, you should focus on integrating your media_player device. Remove the automation part (or uncomment it for later use) and check if HA is starting with just the media_player definition. If it does, it should already offer some basic operations in it’s web-interface for the device.
I have no soundtouch, so what I am proposing is just a hint, probably not a working configuration. Be sure to backup your current configuration before you start to edit.
Hi
I’ve the same problem with my Bose Soundtouch. If I simply define the media player it works, but when I try to define the service to PLAY a preset the server doesn’t restart cause an invalid format of the file configuration.yaml. The strange thing is that one time I’ve defined the service with nano editor and only reloaded the configuration file through the button on the frontend, in that case the service worked. Can anyone help me? Thanks
