Wrong Confir error
HI below is error
17-02-25 16:10:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_data=notification_id=invalid_config, message=The following components and platforms could not be set up:
* sensor.yr
Please check your config, title=Invalid config, service_call_id=1979283920-1, service=create, domain=persistent_notification>
17-02-25 16:10:56 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up:
* sensor.yr
Please check your config; title=Invalid config @ 2017-02-25T16:10:56.677808+05:30>, entity_id=persistent_notification.invalid_config>
i follow this tutorial
and i have cehck comfig file its all ok but still getting error.
any one can help me
below is my config file
  _homeassistant:_
_  # Name of the location where Home Assistant is running_
_  name: Home_
_  # Location required to calculate the time the sun rises and sets_
_  latitude: 31.3256_
_  longitude: 75.5792_
_  # Impacts weather/sunrise data (altitude above sea level in meters)_
_  elevation: 242_
_  # metric for Metric, imperial for Imperial_
_  unit_system: metric_
_  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones_
_  time_zone: Asia/Kolkata_
_# Show links to resources in log and frontend_
_#### This will be removed once you are comfortable with the front end.  It includes links back to home-assistant.io for help topics._
_introduction:_
_# Enables the frontend_
_#### 99% chance you will never need to disable this._
_#### There are no configuration values within the frontend: component _
_frontend:_
_http:_
_  # Uncomment this to add a password (recommended!)_
_  #### This component controls which port Home Assistant run on, SSL configuration, and other tpc/ip and web server configurations.  We will walk through this in future videos._
_  #### Component definition https://home-assistant.io/components/http/_
_  # api_password: PASSWORD_
_# Checks for available updates_
_updater:_
_# Discover some devices automatically_
_#### This component will try to automatically add 11 different uPnP devices.  This includes Chromecast, Wemo Switches, Hue Lights, Netgear routers, Plex, Viera, Roku, Sonos, Yamaha media player, Squeezebox, DirectTV_
_#### I have found this to work about 75% of the time, also this can be slow.  I recommend adding the components manually (We will add Sonos, Philips Hue in the next walk-through)_
_discovery:_
_# Allows you to issue voice commands from the frontend in enabled browsers_
_conversation:_
_# Enables support for tracking state changes over time._
_#### this is great for seeing usage overtime, and understanding when things might not be working exactly the way you want them to_
_##   If you are having resource issues and do not use this function, it is safe to disable._
_history:_
_# View all events in a logbook_
_#### this is great for seeing usage overtime, and understanding when things might not be working exactly the way you want them to.  Similar in a way to history_
_logbook:_
_# Track the sun_
_sun:_
_# Weather Prediction_
_####  This is the default weather sensor.  It gets it's data from the Norwegian Meteorological Institute.  It is a good demo, but we will change to Weather Underground in the next walk-through_
_####  The sensor component can show more than weather, it shows state information (such as temprature) from other entities.  We will walk through entities in the next walk-throughs_
_sensor:_
_  platform: yr_
Please use preformatted text when posting config.yamls no way of helping without the correct format. Also read the error message. Usually tells you what to do…
~Cheers
Sorry for format now ihave done ,lots of error i fixed by checking log,but is there way i update all dependencies at once for HAS,because i dont know almost every component i add it miss some libs.
Your posted config is broken, all those underscore (_) characters won’t be in a working configuration.
Also, the problem is with your sensor configuration. If you check the documentation, you’ll see you’ve got the formatting wrong. It should be:
  - platform: yr
Whereas you’ve apparently got:
  platform: yr
