Wrong consumption smart plug
hello every one.
A have a sonoff plug that counts power in watt. I the app shows about 1,85kw per day.
i made a new sensor in home assistant via utility meter and after that i template via helper so i can have it available in energy dashboard.
i dont know why but is shows me about 4 times more consumption per hour. it should be about 0,07 per hour and shows me 0,26.
any suggestions?
thank you
Wrong order. First the Integral helper (with left method), then the utility meter.
i am sorry i didnt understand you.
the left image is from the ewelink sonoff app
Don’t know how to tell you better.
That is not how to do it. You make a new sensor in HA via the integral helper to create an energy sensor
(use left method)
and then you can create an utility meter to have energy consumption to have data per day/Month/…
Not first an utility meter, and then a helper.
Thank you very much. It worked😉
