Wrong currency in db - unable to store new metrics
Hi
Initially, I had the wrong currency in my settings, later on I’ve corrected it, however, since the latest version, I’m no longer able to have a current cost estimate.
The unit of sensor.3em_channel_a_energy_cost (ILS) does not match the unit of already compiled statistics (EUR). Generation of long term statistics will be suppressed unless the unit changes back to EUR
Assuming this is a bug, I guess I can try to change the currency on the db, any other ideas? thanks.
You have to edit your recorder database statistics_meta table:
UPDATE statistics_meta SET unit_of_measurement = "ILS" WHERE statistic_id = "sensor.3em_channel_a_energy_cost";
thanks @tom_l I’ve successfully update the db, however it seems that its now calculating wrongly, see attached pictures:
where all the sensors are configured with a 0.5 charge rate (e.g. it should be more or less half the KWh)
Strange. I use the “Use an entity with current price” option (cost stored in an input number) and just checked my totals. They’re pretty close (with in a cent or two).
See what happens tomorrow. If it continues you should log a new issue here:
