Wrong data on energy
Hi to all, im insert a wrong data on one sensor and the dashboard is not correct, can i delete this value on sensor.
The sensor is battery and view 9000kwh, but thi is watt. I fixed the sensor but on dashboard i see the wrong data of sensor
Developer Tools → Statistics, then click on the ramp icon next to your entity. Find the time of the erroneous value and either delete it or replace it with an average of nearby values.
thanks for information.
but i fix the data
on the history data i see this
Try clearing your web browser cache.
i try but the data is wrong
Which data point is wrong?
from 12:40 to 13:20 its impossible use 1000 kwh
Your graph does not show 12:40 so I can’t comment on that.
this the graph
You have not shown that you adjusted the value at 12:40, you started at 12:50.
Go back further.
this 12.40
this 12:50
Is that the right date?
Is it the right sensor?
yes the sensor is sensor.fv_batteria_scarica and the date 14/01/2023
:man_shrugging:
Very odd. I can’t explain it.
I think the tool can only adjust long-term statistics, but the graph shows regular recorder history.
Try adding a statistics graph card for your entity and see what it shows.
Yeah that’s it. They are using the History panel to display the value (state), not the Energy panel (LTS).
its the same wrong data
Try hiding the state (stato?) series and only keep the sum (somma) – that’s what the energy dashboard uses.
the sum data its correct
And the bad state will disappear in 10 days.
