In case you expect that your source sensor will provide several subsequent values that are equal, you should opt for the left method to get accurate readings.
Should I understand that it’s not about a high spike but a long-lasting previous value before the spike? If so, it might mean that left method is better in for all devices being turned on and off (lights, ovens, heaters etc) kettles, isn’t it? Shouldn’t be left method default then? Or where the triangle is better?
