HI,
have this template switch:
switch:
switches:
audio_system:
friendly_name: Audio system
value_template: >
{{ is_state('switch.sw_tv_auditorium_cl', 'on') }}
turn_on:
service: script.turn_on
entity_id: script.audio_on
turn_off:
entity_id: script.audio_off
entity_picture_template: >
{% if is_state('switch.audio_system','on') %} /local/activities/hometheater.png
{% else %} /local/activities/book.png
{% endif %}
switch is on and both templates evaluate correctly:
the switch shows with the wrong picture though:
![46](//community-assets.home-assistant.io/original/3X/9/7/97b8124342062d3bf1322fd579d385b1c81fedfb.jpeg)
and dev-state says:
turning it off shows the picture for on:
![24](//community-assets.home-assistant.io/original/3X/6/3/63cb6d7b395d583a859e30704b243689aca19da0.jpeg)
can you spot the error here?
I dont think you can use the template sensor itself as a template for the icon. I think you should use the actual switch.
{% if is_state('switch.sw_tv_auditorium_cl', 'on') %} /local/activities/hometheater.png
{% endif %}
will test of course, but I do that with many other templates without issue. Also imagine creating another sensor with this template, it would still have to reflect the correct state…
seems I mixed up the on/off somewhere in either of the templates?
In that case, you are right. It just didnt make sense when I thought of it.
Check your scripts and their names. Are they accidentally flipped? Maybe the one turning the switch to on, is actually off?
Don’t think so:
audio_on:
sequence:
- service: switch.turn_on
entity_id:
- switch.sw_tv_auditorium_cl
- switch.subwoofer_outlet
- delay:
seconds: 5
entity_id: switch.sw_audio_auditorium_cl
audio_off:
sequence:
- service: switch.turn_off
entity_id:
- delay:
seconds: 5
@argykaraz
it did help, though I find it a bit unpredictable why in this case calling the switch itself turns the value around…
when I use custom-ui, things work out as expected:
switch.audio_system:
show_last_changed: true
# state_card_mode: badges
templates:
theme: >
if (state === 'on') return 'green';
return 'brown';
friendly_name: >
if (state === 'on') return 'Enjoying Home theater';
return 'Enjoying Silence';
entity_picture: >
if (state === 'on') return '/local/activities/hometheater.png';
return '/local/activities/book.png';
![23](//community-assets.home-assistant.io/original/3X/d/4/d48f932d6efabacff6406207c9ab718ceeb19056.jpeg)
![32](//community-assets.home-assistant.io/original/3X/b/f/bfb8e2fd48f1ed040776598df7edbb2019693d80.jpeg)
will make an extra tile out of this. thanks for your help
