Hello.
Seems the validation routine on the gas value under Configuration → Energy throws an error when you add, for example, 2.62 KwH
thing is, I’m not 100% sure where or what config file holds this value to remove it. The logs show that
Digging into this a little more, the error reported in the logs is
digging into the code itself, I’m wondering if this could be one of the issues?
it correctly defines number_energy_price as a float if stat_compensation is set to None. I initially thought this might be the cause of the error, if you supplied a float already
but that doesn’t do much so im kinda lost still.
