Hi there, I recently installed Home Assistant and I detected a wrong message when you configure a switch (mqtt in my case) and you turn it on/off. Despite it works, the message always says there is an error:
“Error al llamar al servicio switch/turn_on”
“Error al llamar al servicio switch/turn_off”
In English the message is correct (no errors), so I guess it is a problem related to the translation that maybe affects to other modules.
