Wrong model with supported device. Help on external converter
Hi, I bought several wired shutter switchfrom Legrand With Netatmo Brand. For what i thought, these devise are supported by zigbee2mqtt
https://www.zigbee2mqtt.io/devices/067776.html
But for each device i included, they are saw as an other model and an other vendor “Bticino”
https://www.zigbee2mqtt.io/devices/K4027C_L4027C_N4027C_NT4027C.html
Is there a way to force the device to be the good model, ? i saw things with external converters, but i don’t underrstand everythink
Can you help me
Can you check those links? …they don’t work for me.
Done. Is this ok now ?
Yes, working now!
when i include the device i got this log
Info 2023-09-07 11:35:12MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"krnnh-1"}'
Info 2023-09-07 11:35:17Device '0x0004740000a41b0f' joined
Info 2023-09-07 11:35:17MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a41b0f","ieee_address":"0x0004740000a41b0f"},"type":"device_joined"}'
Info 2023-09-07 11:35:17Starting interview of '0x0004740000a41b0f'
Info 2023-09-07 11:35:17MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740000a41b0f","ieee_address":"0x0004740000a41b0f","status":"started"},"type":"device_interview"}'
Debug 2023-09-07 11:35:18Received Zigbee message from '0x0004740000a41b0f', type 'readResponse', cluster 'genBasic', data '{"appVersion":0}' from endpoint 1 with groupID 0
Info 2023-09-07 11:35:18Successfully interviewed '0x0004740000a41b0f', device has successfully been paired
Info 2023-09-07 11:35:18Device '0x0004740000a41b0f' is supported, identified as: BTicino Shutter SW with level control (K4027C/L4027C/N4027C/NT4027C)
Info 2023-09-07 11:35:18MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Shutter SW with level control","exposes":[{"features":[{"access":3,"label":"State","name":"state","property":"state","type":"enum","values":["OPEN","CLOSE","STOP"]},{"access":7,"description":"Position of this cover","label":"Position","name":"position","property":"position","type":"numeric","unit":"%","value_max":100,"value_min":0}],"type":"cover"},{"access":1,"description":"Triggered action (e.g. a button click)","label":"Action","name":"action","property":"action","type":"enum","values":["moving","identify",""]},{"access":7,"description":"Enables the LED when the light is turned off, allowing to see the switch in the dark","label":"Led in dark","name":"led_in_dark","property":"led_in_dark","type":"binary","value_off":"OFF","value_on":"ON"},{"access":2,"description":"Blinks the built-in LED to make it easier to find the device","label":"Identify","name":"identify","property":"identify","type":"enum","values":["blink"]},{"access":1,"description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"K4027C/L4027C/N4027C/NT4027C","options":[{"access":2,"description":"Inverts the cover position, false: open=100,close=0, true: open=0,close=100 (default false).","label":"Invert cover","name":"invert_cover","property":"invert_cover","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"Set to true when your device only reports position 0, 100 and 50 (in this case your device has an older firmware) (default false).","label":"No position support","name":"no_position_support","property":"no_position_support","type":"binary","value_off":false,"value_on":true}],"supports_ota":true,"vendor":"BTicino"},"friendly_name":"0x0004740000a41b0f","ieee_address":"0x0004740000a41b0f","status":"successful","supported":true},"type":"device_interview"}'
Info 2023-09-07 11:35:18Configuring '0x0004740000a41b0f'
Info 2023-09-07 11:35:20Successfully configured '0x0004740000a41b0f'
Debug 2023-09-07 11:35:34Received Zigbee message from '0x000474000022cbe5', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"fileVersion":4080131,"imageType":17,"manufacturerCode":4129}' from endpoint 1 with groupID 0
Debug 2023-09-07 11:35:34Device '0x000474000022cbe5' requested OTA
Debug 2023-09-07 11:35:34Check if update available for '0x000474000022cbe5' ( Connected outlet)
Debug 2023-09-07 11:35:34ZigbeeOTA: downloaded main index
Debug 2023-09-07 11:35:34Is new image available for '0x000474000022cbe5', current '{"fieldControl":0,"manufacturerCode":4129,"imageType":17,"fileVersion":4080131}', latest meta '{"fileVersion":5128707,"fileSize":250871,"url":"https://github.com/Koenkk/zigbee-OTA/raw/master/images/Legrand/1021-0011-004e4203-NLP-78.zigbee","sha512":"1fd2b8bb2db0970f00fc87a92b855227001e5456fec5df3e6360c133ba7053bf55c93dbd30a31b6fb672307e57a3649e7b8c1ca92f005767f7ff7704ddde32df"}'
Debug 2023-09-07 11:35:34Update available for '0x000474000022cbe5': YES
Info 2023-09-07 11:35:34MQTT publish: topic 'zigbee2mqtt/0x000474000022cbe5', payload '{"action":null,"led_if_on":null,"led_in_dark":null,"linkquality":164,"power":null,"power_apparent":0,"power_on_behavior":null,"state":null,"update":{"installed_version":4080131,"latest_version":5128707,"state":"available"},"update_available":null}'
Info 2023-09-07 11:35:34Update available for '0x000474000022cbe5'
Debug 2023-09-07 11:35:34Responded to OTA request of '0x000474000022cbe5' with 'NO_IMAGE_AVAILABLE'
Debug 2023-09-07 11:35:39Received Zigbee message from '0x000474000022cbe5', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"fileVersion":4080131,"imageType":17,"manufacturerCode":4129}' from endpoint 1 with groupID 0
Debug 2023-09-07 11:35:39Device '0x000474000022cbe5' requested OTA
Debug 2023-09-07 11:35:46Received Zigbee message from '0x000474000022cbe5', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"fileVersion":4080131,"imageType":17,"manufacturerCode":4129}' from endpoint 1 with groupID 0
Debug 2023-09-07 11:35:46Device '0x000474000022cbe5' requested OTA
Debug 2023-09-07 11:35:57Received Zigbee message from '0x000474000022cbe5', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"fileVersion":4080131,"imageType":17,"manufacturerCode":4129}' from endpoint 1 with groupID 0
Debug 2023-09-07 11:35:57Device '0x000474000022cbe5' requested OTA
How can i transform this model into since one https://www.zigbee2mqtt.io/devices/067776.html
Did you try ‘reconfigure’ ?
