Wrong time on Telegram notify
since last night all telegram notify has a wrong time.
The time showed is UTC intead of my zone time (UTC+2).
sensor.time is ok as well as {{ now() }} function.
Zone are configurated correctly in configuration.yaml (time_zone: Europe/Rome)
Any help is appreciated.
Regards,
Alessandro
What does your telegram config look like?
Did you change anything since last night? Update What version are you on?
My telegram config seems ok. I don’t think there is a time config in it.
Las t night i’ve changed only this automation: - service: script.my_notify data_template: call_no_annuncio: 1 media_player_google: media_player.nesthub7132 # Using multi-line notation allows for easier quoting message: > ATTENZIONE! Allarme disinserito {{ as_timestamp(now()) | timestamp_custom('%H:%M %d %B %Y') }}
Hassio version 107.7
What is the time on the machine running home assistant?
Can you ssh in and run the command: date
Python is just going to use your system clock to determine the time. Everything you have there looks right…
Is as_timestamp(now()) not always using the UTC time instead of your UTC+2?
Time is ok through ssh command:
Cattura
just converts time to a number. now() returns local datetime object and utctime() returns UTC - here’s more.
Since midnight, Hassio showing correct time.
