Hi, i’m starting with HA and sonoff devices and have an issue with the MQTT auto-discovery of the sonoff 4 channel device with the tasmota firmware.
When i set the %topic% in the sonoff device at ‘4channel’ and start the auto-discovery in the console (setoption 19 on)
The console output gives me this.
00:00:00 Project sonoff 4ch1 Version 6.5.0.1(sonoff)-2_4_2
00:00:00 WIF: Connecting to AP1 PetboxNW24 in mode 11N as 4channel-5629…
00:00:04 WIF: Connected
00:00:04 HTP: Web server active on 4channel-5629 with IP address 192.168.1.10
22:09:48 MQT: Attempting connection…
22:09:48 MQT: Connected
22:09:48 MQT: 4channel/tele/LWT = Online (retained)
22:09:48 MQT: 4channel/cmnd/POWER =
22:09:48 MQT: 4channel/tele/INFO1 = {“Module”:“Sonoff 4CH”,“Version”:“6.5.0.1(sonoff)”,“FallbackTopic”:“cmnd/DVES_8255FD_fb/”,“GroupTopic”:“sonoffs”}
22:09:48 MQT: 4channel/tele/INFO2 = {“WebServerMode”:“Admin”,“Hostname”:“4channel-5629”,“IPAddress”:“192.168.1.10”}
22:09:48 MQT: 4channel/tele/INFO3 = {“RestartReason”:“Software/System restart”}
22:09:48 MQT: 4channel/stat/RESULT = {“POWER1”:“ON”}
22:09:48 MQT: 4channel/stat/POWER1 = ON
22:09:48 MQT: 4channel/stat/RESULT = {“POWER2”:“OFF”}
22:09:48 MQT: 4channel/stat/POWER2 = OFF
22:09:48 MQT: 4channel/stat/RESULT = {“POWER3”:“OFF”}
22:09:48 MQT: 4channel/stat/POWER3 = OFF
22:09:48 MQT: 4channel/stat/RESULT = {“POWER4”:“OFF”}
22:09:48 MQT: 4channel/stat/POWER4 = OFF
22:09:49 MQT: homeassistant/light/8255FD_LI_1/config = (retained)
22:09:49 MQT: homeassistant/switch/8255FD_RL_1/config = {“name”:“4ch1”,“cmd_t”:“~cmnd/POWER1”,“stat_t”:“~tele/STATE”,“val_tpl”:“{{value_json.POWER1}}”,“pl_off”:“OFF”,“pl_on”:“ON”,“avty_t”:“~tele/LWT”,“pl_avail”:“Online”,“pl_not_avail”:“Offline”,“uniq_id”:“8255FD_RL_1”,“device”:{“identifiers”:[“8255FD”]},“~”:“4channel/”} (retained)
22:09:49 MQT: homeassistant/light/8255FD_LI_2/config = (retained)
22:09:49 MQT: homeassistant/switch/8255FD_RL_2/config = {“name”:“4ch2”,“cmd_t”:“~cmnd/POWER2”,“stat_t”:“~tele/STATE”,“val_tpl”:“{{value_json.POWER2}}”,“pl_off”:“OFF”,“pl_on”:“ON”,“avty_t”:“~tele/LWT”,“pl_avail”:“Online”,“pl_not_avail”:“Offline”,“uniq_id”:“8255FD_RL_2”,“device”:{“identifiers”:[“8255FD”]},“~”:“4channel/”} (retained)
22:09:49 MQT: homeassistant/light/8255FD_LI_3/config = (retained)
22:09:49 MQT: homeassistant/switch/8255FD_RL_3/config = {“name”:“4ch3”,“cmd_t”:“~cmnd/POWER3”,“stat_t”:“~tele/STATE”,“val_tpl”:“{{value_json.POWER3}}”,“pl_off”:“OFF”,“pl_on”:“ON”,“avty_t”:“~tele/LWT”,“pl_avail”:“Online”,“pl_not_avail”:“Offline”,“uniq_id”:“8255FD_RL_3”,“device”:{“identifiers”:[“8255FD”]},“~”:“4channel/”} (retained)
22:09:49 MQT: homeassistant/light/8255FD_LI_4/config = (retained)
22:09:49 MQT: homeassistant/switch/8255FD_RL_4/config = {“name”:“4ch4”,“cmd_t”:“~cmnd/POWER4”,“stat_t”:“~tele/STATE”,“val_tpl”:“{{value_json.POWER4}}”,“pl_off”:“OFF”,“pl_on”:“ON”,“avty_t”:“~tele/LWT”,“pl_avail”:“Online”,“pl_not_avail”:“Offline”,“uniq_id”:“8255FD_RL_4”,“device”:{“identifiers”:[“8255FD”]},“~”:“4channel/”} (retained)
22:09:49 MQT: homeassistant/light/8255FD_LI_5/config = (retained)
22:09:49 MQT: homeassistant/switch/8255FD_RL_5/config = (retained)
22:09:49 MQT: homeassistant/light/8255FD_LI_6/config = (retained)
22:09:49 MQT: homeassistant/switch/8255FD_RL_6/config = (retained)
22:09:49 MQT: homeassistant/light/8255FD_LI_7/config = (retained)
22:09:49 MQT: homeassistant/switch/8255FD_RL_7/config = (retained)
22:09:49 MQT: homeassistant/light/8255FD_LI_8/config = (retained)
22:09:49 MQT: homeassistant/switch/8255FD_RL_8/config = (retained)
22:09:49 MQT: homeassistant/sensor/8255FD_status/config = {“name”:“4ch1 status”,“stat_t”:“~HASS_STATE”,“avty_t”:“~LWT”,“pl_avail”:“Online”,“pl_not_avail”:“Offline”,“json_attributes_topic”:“~HASS_STATE”,“unit_of_meas”:" “,“val_tpl”:”{{value_json[‘RSSI’]}}“,“uniq_id”:“8255FD_status”,“device”:{“identifiers”:[“8255FD”],“name”:“4ch1”,“model”:“Sonoff 4CH”,“sw_version”:“6.5.0.1(sonoff)”,“manufacturer”:“Tasmota”},”~":“4channel/tele/”} (retained)
22:09:56 MQT: 4channel/tele/STATE = {“Time”:“2019-03-24T22:09:56”,“Uptime”:“0T00:00:14”,“Vcc”:3.394,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER1”:“ON”,“POWER2”:“OFF”,“POWER3”:“OFF”,“POWER4”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“PetboxNW24”,“BSSId”:“64:D1:A3:42:28:26”,“Channel”:5,“RSSI”:100,“LinkCount”:1,“Downtime”:“0T00:00:04”}}
That looks OK for me. But within HA the newly discovered device looks like the attached image.
I don’t understand why the switch are named with ‘switch.sonoff’ instead of ‘switch.4channel’ as i expected. What am i doing wrong ?
