Thanks for hearing my problem. I’m shortly before freak out.
It try to add addressable LED Strip to my daughters bed. I bought 5m 12v ws2811. Everything is relay straight forward with theses LEDs
My problem:
The first three LEDs in the strip are not doing what there are supposed to do. I learned that ws2811 is ordered in groups of three by the ICs on the strip. If i run eg. rainbow effect the also do change color but not in line with the other. Worst part is that the first 3 LEDs not turn off when I turn off the strip. Terrible for the night. Do I miss something? Wiring: all GND together, Vcc to Vcc and Data to GPIO 5.
light:
- platform: neopixelbus
type: GRB
variant: WS2811
pin: GPIO5
#114
num_leds: 111
effects:
- random:
transition_length: 4s
update_interval: 5s
- addressable_rainbow:
name: Rainbow Effect With Custom Values
speed: 5 #geschwindigkeit: kleiner langsamer
width: 35 #blockgröße
- addressable_random_twinkle:
name: Random Twinkle Effect With Custom Values
twinkle_probability: 5%
progress_interval: 15ms
- platform: partition
name: "Partition Light 1"
segments:
- id: lichtunten
to: 2
For Troubleshooting I tried partition to see if there are part of the strip for the strip or if there are out. I With this partition the first 3 in the strip have eg. red while the next 9 LED have a different color. So the strip places the first 3 LEDs somewhere else.
I already cut off the first 3 because I thought the IC might be dead. Same behavior after the cut.
I haven’t not uesed a, how is it called, level shifter (3V3 → 5V) because the rest of the strip is working fine.
What do I miss? Do I need a sort of thermination? I tried all available libs for this strip:
light: fastled_clockless
, varient: 800KBPS
etc.
