ferbar
(Christian Ferbar)
December 23, 2020, 10:27pm
1
Which effects do you use for led strings or strips?
I found the following configs quite nice, maybe somone else will find the code usefull, too
effects:
- addressable_random_twinkle:
name: Random Twinkle 20%
twinkle_probability: 20%
progress_interval: 32ms
name: Random Twinkle 80%
twinkle_probability: 80%
- addressable_scan:
scan_width: 4
- addressable_color_wipe:
- addressable_rainbow:
- addressable_fireworks:
update_interval: 32ms
spark_probability: 30%
use_random_color: false
fade_out_rate: 120
random twinkle:
ferbar
(Christian Ferbar)
December 23, 2020, 10:29pm
2
Red, Green, White Leds, pulsating
effects:
- addressable_lambda:
name: "Christmas RedGreenWhite"
lambda: |-
static uint8_t *xLedInc=NULL;
static int *xLedDim=NULL; // -255 ... 255
static ESPColor *xLedColor=NULL;
// ..... creates compiler warning .....
#define getColor() \
ESPColor color; \
switch( (int) floor( random_uint32() / (double(UINT32_MAX)+1) * 3)) { \
case 0: color=light::ESPColor(255, 0, 18); break; \
case 1: color=light::ESPColor(0, 179, 44); break; \
default: color=light::ESPColor(255, 255, 255); break; \
int dim=127+random_float()*128; \
xLedColor[i]=color*dim;
if(xLedInc==NULL) {
xLedInc=new uint8_t[it.size()];
xLedDim=new int[it.size()];
xLedColor=new ESPColor[it.size()];
for(int i=0; i < it.size(); i++) {
xLedInc[i]=random_float()*8;
xLedDim[i]=random_float()*511-255;
getColor();
// ESP_LOGD(TAG, "init [%d]=> b:%d %02x %02x %02x => %02x %02x %02x", i, dim, color.red, color.green, color.blue, xLedColor[i].red, xLedColor[i].green, xLedColor[i].blue);
for (int i = 0; i < it.size(); i++) {
int dim=255 - abs(xLedDim[i]);
ESPColor color=xLedColor[i] * dim;
// if(i==0) ESP_LOGD(TAG, "[0]=> b:%d %02x %02x %02x",dim, color.red, color.green, color.blue);
it[i] = color;
xLedDim[i]+=xLedInc[i];
if(xLedDim[i] > 255) {
xLedDim[i]=-255;
getColor();
ferbar
(Christian Ferbar)
December 23, 2020, 10:33pm
3
color shift
effects:
update_interval: 16ms
lambda: |-
if(random_float() > 0.7)
it[0] = ESPColor::random_color();
else
it[0] = ESPColor::BLACK;
for (int i = it.size() -1 ; i > 0; i--) {
it[i] = it[i - 1].get();
ferbar
(Christian Ferbar)
December 23, 2020, 10:35pm
4
slow color change:
effects:
lambda: |-
static ESPColor *xLedTargetColor=NULL;
static ESPColor *xLedCurrColor=NULL;
if(xLedTargetColor==NULL) {
xLedTargetColor=new ESPColor[it.size()];
xLedCurrColor=new ESPColor[it.size()];
xLedCurrColor[i]=it[i].get();
xLedTargetColor[i]=ESPColor::random_color();
// ESPColor target= xLedTargetColor[i];
// ESP_LOGD(TAG, "init [%d]=> %02x %02x %02x", i, target.red, target.green, target.blue);
ESPColor &c=xLedCurrColor[i];
ESPColor org=c;
if(c.red == target.red && c.green == target.green && c.blue == target.blue) {
// target= xLedTargetColor[i];
if(c.red < target.red) {
c.red++;
} else if(c.red > target.red) {
c.red--;
if(c.green < target.green) {
c.green++;
} else if(c.green > target.green) {
c.green--;
if(c.blue < target.blue) {
c.blue++;
} else if(c.blue > target.blue) {
c.blue--;
// ESP_LOGD(TAG, "change [%d]=> %02x %02x %02x => %02x %02x %02x", i, c.red, c.green, c.blue, target.red, target.green, target.blue);
it[i] = c;
// if(i==0) ESP_LOGD(TAG, "change [%d]=> %02x %02x %02x => %02x %02x %02x", i, org.red, org.green, org.blue, it[i].get_red(), it[i].get_green(), it[i].get_blue());
ferbar
(Christian Ferbar)
December 23, 2020, 10:41pm
5
starry sky - random leds fading in/out slowly + comets
esphome:
[snip]
includes:
- colorTempToRGB.h
- starsLambda.h
[snip]
effects:
update_interval: 10ms
lambda: |-
starsLambda(it);
starsLambda.h: esphome starry sky lambda function Β· GitHub
colorTempToRGB.h: Color Temperature to RGB Β· GitHub
GlennHA
(Glenn)
December 24, 2020, 4:50am
6
Feel free to use some of my code for more effects:
https://github.com/GlennGoddard/Lights
This is python but you can get the gist of it.
If you want to watch it (this is old, I have done updates since this video but get the idea across)
https://www.youtube.com/watch?v=RyhVeMgjnR4
sparkydave
(π¦πΊ Dave)
December 24, 2020, 5:12am
7
It would be awesome if you could submit these effects as a PR to the ESPhome GitHub repo. The existing effects are pretty limited which is why I stopped using it for LED strips, switched to WLED. ESPhome has itβs benefit in that you can do more with a node than just the lights whereas WLED is purely for the LED strip so having extra effects would sway the decision a little more towards ESPhome.
ferbar
(Christian Ferbar)
December 26, 2020, 9:48am
8
Thanks for the ideas, I will have a look at it.
Another one, candle like flickering:
(imagine a colorfull yellow, orange, red video )
lambda: |-
static int *target=NULL;
static int *curr=NULL;
static int *inc=NULL;
static int *state=NULL;
static int *startState=NULL;
static int *stateLen=NULL;
static ESPColor *targetColor=NULL;
static ESPColor *currColor=NULL;
if(state==NULL) {
target=new int[it.size()];
curr=new int[it.size()];
inc=new int[it.size()];
state=new int[it.size()];
startState=new int[it.size()];
stateLen=new int[it.size()];
targetColor=new ESPColor[it.size()];
currColor=new ESPColor[it.size()];
if(initial_run) {
curr[i]=0; target[i]=0; // curr==target => init
inc[i]=0; state[i]=0; startState[i]=0; stateLen[i]=0;
currColor[i] = it[i].get();
targetColor[i] = it[i].get();
for (int i = 0; i < it.size() ; i++) {
if(state[i] == 0 || state[i] > 500) {
state[i] = random(500); // random delay till first flicker
target[i] = curr[i]; // init new target
// set new target if target reached
if(state[i] == 450 || (curr[i] == target[i] && state[i] > 450)) { // 10% is disturbed candle
target[i]=random(50, 255);
inc[i]=random(50)+1;
currColor[i]=targetColor[i];
targetColor[i]=current_color+ESPColor::random_color()*random(100);
stateLen[i]=abs(target[i]-curr[i]) / inc[i];
startState[i]=state[i];
} else if(curr[i] == target[i]) { // slow changing candle
target[i]=random(80, 160);
inc[i]=random(10)+1;
targetColor[i]=current_color+ESPColor::random_color()*random(40);
if(curr[i] > target[i]) {
curr[i]-=min(inc[i], curr[i]-target[i]);
} else {
curr[i]+=min(inc[i], target[i]-curr[i]);
// ESP_LOGD(TAG, "candle [%d]3", i); delay(10);
int factor=255;
if(stateLen[i] > 0) factor = 255 * (state[i] - startState[i]) / (stateLen[i]);
ESPColor c=currColor[i]*(factor*(curr[i]+1)/256) + targetColor[i]*((255-factor)*(curr[i]+1)/256);
it[i]=c;
// it[i]=it[i]*curr[i];
state[i]++;
// if(i==0) ESP_LOGD(TAG, "candle [0]=> t:%d c:%d inc:%d state:%d startState:%d stateLen:%d factor:%d cc:%02x tc:%02x out=%02x",
// target[i], curr[i], inc[i], state[i], startState[i], stateLen[i],
// factor, currColor[i].red, targetColor[i].red, c.red);
depending on the random value in
you get more/less color change
The base color is depending on the choosen color from the color picker.
Hello! I recently added my 1st WLED set up and like it!
How or where do I upload these codes to use? Is it in HomeAssistant because I do not see anywhere to load them.
sparkydave
(π¦πΊ Dave)
December 9, 2021, 4:23am
10
That is yaml for ESPhome, nothing to do with WLED. The effects in WLED are better than what you will find available for ESPhome.
