Im trying to use an effect on a WS2812 strip where I have partitioned off the LED’s to indicate certain states (like Wifi Connected and API connected).
It appears that effects dont seem to work with partitions.
Is this a bug or am i doing something wrong
wifi:
networks:
- ssid: !secret wifi_ssid
on_connect:
then:
- light.turn_on:
effect: "online"
on_disconnect:
then:
- light.turn_on:
effect: "offline"
api:
on_client_disconnected:
then:
- light.turn_on:
effect: "offline"
on_client_connected:
then:
- light.turn_on:
effect: "online"
light:
- platform: esp32_rmt_led_strip
rgb_order: grb
pin: GPIO15
num_leds: 5
rmt_channel: 0
chipset: WS2812
default_transition_length: 0s
effects:
- strobe:
colors:
- state: true
brightness: 100%
red: 100%
green: 0%
blue: 0%
duration: 250ms
- state: false
duration: 250ms
- state: true
brightness: 100%
red: 100%
green: 0%
blue: 0%
duration: 250ms
- state: false
duration: 250ms
- state: true
brightness: 100%
red: 100%
green: 0%
blue: 0%
duration: 250ms
- state: false
duration: 2s
- strobe:
colors:
- state: true
brightness: 100%
red: 0%
green: 100%
blue: 0%
duration: 250ms
- state: false
duration: 250ms
- state: true
brightness: 100%
red: 0%
green: 100%
blue: 100%
duration: 250ms
- state: false
duration: 2s
- platform: partition
segments:
- id: led
to: 0
segments:
- id: led
to: 1
If i supply color and brightness parameters to each of the - light.turn_on
statements the colors work, but effects do not.
