NOW I ASK ME ONE THING.
I TRY TO CONFIGURE AN ADDRESSABLE WS2812 LED STRIP.
I LOAD THIS ON ESP HOME BUT IT DOES NOT WORK.
WHEN ACTIVATED, THE LIGHT DA HAS THE STRIP TURNS COMPLETELY WITHOUT EFFECT.
THEN THE EXAMPLE IN ESPHOME IS VERY DOCUMENTED.
THE EXAMPLES MUST BE DESCRIBED CORRECTLY.
WHAT REASON THERE IS TO WRITE
light:
- platformer: …
WHAT ARE THESE DOTS?
# Example configuration entrlight:
light:
- platformer: fastled_clockless
chipset: WS2811
pin: D1
num_leds: 6
rgb_order: BRG
name: "FastLED WS2811 Light"
effects:
- automation:
name: Custom Automation Effect
sequence:
- light.addressable_set:
red: 100%
green: 100%
blue: 100%
- delay: 100ms
range_from: 0
range_to: 20
red: 100%
green: 0%
blue: 0%
