I’m trying to program some changes to the node configuration for my WT00Z-1. For basic things such as setting the LED Mode to “LED is always OFF”, it should be pretty obvious when the node properly received the change in config (i.e., the LED would turn off). However, it doesn’t seem to be taking. This is the output of the OZW Log:
2020-01-23 07:06:45.687 Info, Node011, Value::Set - COMMAND_CLASS_CONFIGURATION - LED Mode - 3 - 1 - LED is always OFF
2020-01-23 07:06:45.687 Info, Node011, Configuration::Set - Parameter=3, Value=3 Size=1
2020-01-23 07:06:45.688 Detail, Node011, Queuing (Send) ConfigurationCmd_Set (Node=11): 0x01, 0x0c, 0x00, 0x13, 0x0b, 0x05, 0x70, 0x04, 0x03, 0x01, 0x03, 0x25, 0x7e, 0xc0
2020-01-23 07:06:45.688 Detail, Node011, Queuing (Send) ConfigurationCmd_Get (Node=11): 0x01, 0x0a, 0x00, 0x13, 0x0b, 0x03, 0x70, 0x05, 0x03, 0x25, 0x7f, 0xc2
2020-01-23 07:06:45.692 Detail,
2020-01-23 07:06:45.692 Info, Node011, Sending (Send) message (Callback ID=0x7e, Expected Reply=0x13) - ConfigurationCmd_Set (Node=11): 0x01, 0x0c, 0x00, 0x13, 0x0b, 0x05, 0x70, 0x04, 0x03, 0x01, 0x03, 0x25, 0x7e, 0xc0
2020-01-23 07:06:45.702 Detail, Node011, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-01-23 07:06:45.702 Detail, Node011, ZW_SEND_DATA delivered to Z-Wave stack
2020-01-23 07:06:45.718 Detail, Node011, Received: 0x01, 0x07, 0x00, 0x13, 0x7e, 0x00, 0x00, 0x02, 0x97
2020-01-23 07:06:45.718 Detail, Node011, ZW_SEND_DATA Request with callback ID 0x7e received (expected 0x7e)
2020-01-23 07:06:45.719 Info, Node011, Request RTT 25 Average Request RTT 26
2020-01-23 07:06:45.719 Detail, Expected callbackId was received
2020-01-23 07:06:45.719 Detail, Expected reply was received
2020-01-23 07:06:45.719 Detail, Message transaction complete
2020-01-23 07:06:45.719 Detail, Node011, Removing current message
2020-01-23 07:06:45.719 Info, Node011, Sending (Send) message (Callback ID=0x7f, Expected Reply=0x04) - ConfigurationCmd_Get (Node=11): 0x01, 0x0a, 0x00, 0x13, 0x0b, 0x03, 0x70, 0x05, 0x03, 0x25, 0x7f, 0xc2
2020-01-23 07:06:45.727 Detail, Node011, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2020-01-23 07:06:45.730 Detail, Node011, ZW_SEND_DATA delivered to Z-Wave stack
2020-01-23 07:06:45.745 Detail, Node011, Received: 0x01, 0x07, 0x00, 0x13, 0x7f, 0x00, 0x00, 0x03, 0x97
2020-01-23 07:06:45.745 Detail, Node011, ZW_SEND_DATA Request with callback ID 0x7f received (expected 0x7f)
2020-01-23 07:06:45.746 Info, Node011, Request RTT 26 Average Request RTT 26
2020-01-23 07:06:45.746 Detail, Expected callbackId was received
2020-01-23 07:06:45.755 Detail, Node011, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0b, 0x05, 0x70, 0x06, 0x03, 0x01, 0x01, 0x8b
2020-01-23 07:06:45.756 Info, Node011, Response RTT 36 Average Response RTT 38
2020-01-23 07:06:45.756 Detail, Node011, Refreshed Value: old value=1, new value=1, type=list
2020-01-23 07:06:45.756 Detail, Node011, Changes to this value are not verified
2020-01-23 07:06:45.756 Info, Node011, Received Configuration report: Parameter=3, Value=1
2020-01-23 07:06:45.756 Detail, Node011, Expected reply and command class was received
2020-01-23 07:06:45.756 Detail, Node011, Message transaction complete
2020-01-23 07:06:45.756 Detail, Node011, Removing current message
2020-01-23 07:06:45.757 Detail, Node011, Notification: ValueChanged
