I have a WT32-ETH01 that i am trying to use for climate control in my broiler.
When i use the MCU for controlling relays, everything works fine but when i try to add
i2c bus, WT32-ETH01 takes about 1 min to boot after that i can only ping the MCU but WT32-eth01 loses connectivity with home assistant
Yaml code is as follow:
esphome:
friendly_name: WT32-ETH01
esp32:
board: esp32dev
framework:
type: arduino
web_server:
local: True
port: 80
# While using Docker esphome mDNS cannot resolve IP
# since it's done by homeassistant
mdns:
disabled: True
# Enable logging
logger:
logs:
component: ERROR
# Enable Home Assistant API
api:
encryption:
key: "Y8UtoZvKVPWDRl6mpHa84qCjs24LseEzEBP8gd/wUdQ="
ota:
password: "622d911039ea35909f0e10463ffdb4e0"
# Ethernet Config
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 1
power_pin: GPIO16
manual_ip:
static_ip: 192.168.110.12
subnet: 255.255.255.0
gateway: 192.168.110.1
dns1: 192.168.110.1
# i2c:
# sda: 32
# scl: 33
# scan: true
# id: bus_b
# frequency: 1kHz
switch:
- platform: gpio
icon: mdi:lightbulb-on
pin:
number: 4
inverted: True
restore_mode: always_off
# Restarts MCU
button:
- platform: restart
name: Restart - ETH01
