I have a wt32-eth01 microcontroller that I am planning to use as a thermostat in my future home. I managed to make it work with a bme280 through i2c and climate control module.
I would like to add a display to it, but I cannot find any information on how to wire it up to this board.
The screen I am trying to use is a 1.8 inch TFT display with ST7735 driver that support SPI.
I would appreciate some help wiring this thing up. I thought it would be easier to find a pinout diagram that tells me which are the spi pins…
I would just use I2C for both the bmp280 and your display. Just make sure you use a different address for each. They both can use the same pins, which normally are 22 for sck and 21 for
sda. Some boards differ. The address for the bmp is 0x76 and many displays use 0x3C. Check your documentation for your display board. There are many cheap generic OLED boards you can get for about $3.00. I hope this helps.
