My SC01 plus has been working great - until the latest ESPHome 2025.7.0 update. Was working fine with the 2025.6.x version… Any ideas?
INFO ESPHome 2025.7.0
INFO Reading configuration /config/esphome/sc01-plus-1.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing sc01-plus-1 (board: esp32-s3-devkitc-1; framework: arduino; platform: https://github.com/pioarduino/platform-espressif32/releases/download/53.03.13/platform-espressif32.zip)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
- framework-arduinoespressif32 @ 3.1.3
- framework-arduinoespressif32-libs @ 5.3.0+sha.489d7a2b3a
- tool-esptoolpy @ 4.8.6
- tool-mklittlefs @ 3.2.0
- tool-riscv32-esp-elf-gdb @ 14.2.0+20240403
- tool-xtensa-esp-elf-gdb @ 14.2.0+20240403
- toolchain-riscv32-esp @ 13.2.0+20240530
- toolchain-xtensa-esp-elf @ 13.2.0+20240530
Dependency Graph
|-- Networking @ 3.1.3
|-- AsyncTCP @ 3.4.5
|-- WiFi @ 3.1.3
|-- FS @ 3.1.3
|-- Update @ 3.1.3
|-- ESPAsyncWebServer @ 3.7.10
|-- ESPmDNS @ 3.1.3
|-- noise-c @ 0.1.10
|-- ArduinoJson @ 7.4.2
|-- LovyanGFX @ 1.2.7
|-- lvgl @ 8.4.0
Compiling .pioenvs/sc01-plus-1/src/main.cpp.o
Compiling .pioenvs/sc01-plus-1/lib0f0/ESPAsyncWebServer/WebServer.cpp.o
Compiling .pioenvs/sc01-plus-1/lib915/ESPmDNS/ESPmDNS.cpp.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Archiving .pioenvs/sc01-plus-1/lib915/libESPmDNS.a
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_core/salsa/ref/core_salsa_ref.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_hash/crypto_hash.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
/config/esphome/sc01-plus-1.yaml: In function 'void setup()':
/config/esphome/sc01-plus-1.yaml:676:78: error: no matching function for call to 'esphome::Automation<long int>::Automation(esphome::ha_deck::HdSliderChangeTrigger*&)'
676 |
In file included from src/esphome/components/sensor/filter.h:6,
from src/esphome/components/sensor/sensor.h:7,
from src/esphome/core/application.h:29,
from src/esphome/components/api/api_frame_helper.h:17,
from src/esphome/components/api/api_connection.h:5,
from src/esphome.h:3,
from src/main.cpp:3:
src/esphome/core/automation.h:286:12: note: candidate: 'esphome::Automation<Ts>::Automation(esphome::Trigger<Ts ...>*) [with Ts = {long int}]'
286 | explicit Automation(Trigger<Ts...> *trigger) : trigger_(trigger) { this->trigger_->set_automation_parent(this); }
src/esphome/core/automation.h:286:39: note: no known conversion for argument 1 from 'esphome::ha_deck::HdSliderChangeTrigger*' to 'esphome::Trigger<long int>*'
src/esphome/core/automation.h:284:32: note: candidate: 'constexpr esphome::Automation<long int>::Automation(const esphome::Automation<long int>&)'
284 | template<typename... Ts> class Automation {
src/esphome/core/automation.h:284:32: note: no known conversion for argument 1 from 'esphome::ha_deck::HdSliderChangeTrigger*' to 'const esphome::Automation<long int>&'
src/esphome/core/automation.h:284:32: note: candidate: 'constexpr esphome::Automation<long int>::Automation(esphome::Automation<long int>&&)'
src/esphome/core/automation.h:284:32: note: no known conversion for argument 1 from 'esphome::ha_deck::HdSliderChangeTrigger*' to 'esphome::Automation<long int>&&'
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Archiving .pioenvs/sc01-plus-1/lib0f0/libESPAsyncWebServer.a
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_stream/crypto_stream.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_stream/salsa20/ref/salsa20_ref.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_stream/salsa20/stream_salsa20.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_stream/salsa20/xmm6/salsa20_xmm6-asm.S.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_stream/salsa20/xmm6/salsa20_xmm6.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_stream/salsa20/xmm6int/salsa20_xmm6int-avx2.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_stream/salsa20/xmm6int/salsa20_xmm6int-sse2.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/crypto_verify/verify.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/randombytes/internal/randombytes_internal_random.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/randombytes/randombytes.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/randombytes/sysrandom/randombytes_sysrandom.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/sodium/codecs.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/sodium/core.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/sodium/runtime.c.o
Compiling .pioenvs/sc01-plus-1/lib761/libsodium/sodium/utils.c.o
Compiling .pioenvs/sc01-plus-1/lib5f8/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling .pioenvs/sc01-plus-1/lib5f8/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling .pioenvs/sc01-plus-1/lib5f8/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling .pioenvs/sc01-plus-1/lib5f8/noise-c/backend/ref/dh-curve25519.c.o
Compiling .pioenvs/sc01-plus-1/lib5f8/noise-c/backend/ref/hash-blake2b.c.o
Archiving .pioenvs/sc01-plus-1/lib761/libsodium.a
Compiling .pioenvs/sc01-plus-1/lib5f8/noise-c/backend/ref/hash-blake2s.c.o
Compiling .pioenvs/sc01-plus-1/lib5f8/noise-c/backend/ref/hash-sha256.c.o
*** [.pioenvs/sc01-plus-1/src/main.cpp.o] Error 1
========================= [FAILED] Took 20.47 seconds =========================
SCREEN_MAIN: master
SCREEN_ROOMS: rooms
SCREEN_KITCHEN: sliders
SCREEN_LED: led
SCREEN_SOLAR: solar
SCREEN_LIGHTS: lights
esphome:
friendly_name: SC01-Plus-1
# In this way, custom partitions can be configured and flushed (not over OTA!)
# platformio_options:
# board_upload.maximum_ram_size: 327680
# board_upload.maximum_size: 16777216
# board_build.partitions: "../../../custom_partitions_3584.csv"
includes:
- bthome_ble_custom.h
esp32:
framework:
type: arduino
flash_size: 16MB
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxx"
ota:
- platform: esphome
password: "xxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Sc01-Plus-1 Fallback Hotspot"
password: "xxx"
external_components:
- source:
type: git
url: https://github.com/strange-v/ha_deck
ref: main
components: [ hd_device_sc01_plus, ha_deck ]
web_server:
port: 80
time:
- platform: sntp
timezone: Pacific/Auckland
on_time:
- cron: '* * * * * *'
then:
lambda: |-
char buff[10] = "-";
auto time = id(sntp_time).now();
if (time.is_valid())
sprintf(buff, "%02d:%02d:%02d", time.hour, time.minute, time.second);
id(local_time).set_value(std::string(buff));
# Enable BLE
esp32_ble:
one_wire:
- platform: gpio
pin: GPIO12
switch:
- platform: output
output: buzzer_output
on_turn_on:
then:
- output.turn_on: buzzer_output
- output.ledc.set_frequency:
frequency: "1000Hz"
- output.set_level:
level: "50%"
on_turn_off:
then:
- output.turn_off: buzzer_output
- platform: dallas_temp
name: SC01-1 Temperature
update_interval: 120s
filters:
- calibrate_linear:
method: least_squares
datapoints:
- 0.0 -> 0.0
- 23.0 -> 24.0
on_value:
then:
- lambda: |-
BTHomeAdvertiser::broadcast_temperature(id(sc01_1_temp).state);
- logger.log: "#####################"
- logger.log: id(sc01_1_temp).state
- platform: homeassistant
entity_id: sensor.outside_temperature
internal: true
entity_id: sensor.28372f8cb98c_ac_home
internal: true
entity_id: sensor.28372f8cb98c_ac_target
internal: true
#North Solar
#sensor.esp8266_modbus_phase_1_current_watts
entity_id: sensor.esp8266_modbus_phase_1_current_watts
internal: true
#sensor.esp8266_modbus_phase_2_current_watts
entity_id: sensor.esp8266_modbus_phase_2_current_watts
internal: true
#sensor.esp8266_modbus_phase_3_current_watts
entity_id: sensor.esp8266_modbus_phase_3_current_watts
internal: true
#South solar
#sensor.esp8266_modbus_fronius_phase_1_current_watts
entity_id: sensor.esp8266_modbus_fronius_phase_1_current_watts
internal: true
#sensor.esp8266_modbus_fronius_phase_2_current_watts
entity_id: sensor.esp8266_modbus_fronius_phase_2_current_watts
internal: true
#Total Solar
#sensor.phase_1_total_solar_power
entity_id: sensor.phase_1_total_solar_power
internal: true
#sensor.phase_2_total_solar_power
entity_id: sensor.phase_2_total_solar_power
internal: true
#sensor.phase_3_total_solar_power
entity_id: sensor.phase_3_total_solar_power
internal: true
#Grid:
#sensor.paladin_p1
entity_id: sensor.paladin_p1
internal: true
#sensor.phase_2
internal: true
#sensor.phase_3
internal: true
text_sensor:
entity_id: sensor.heat_pump_mode
internal: true
entity_id: sensor.heat_pump_status
internal: true
number:
name: Active screen brightness
min_value: 0
max_value: 100
step: 5
initial_value: 75
restore_value: true
set_action:
- lambda: |-
if (!id(deck).get_inactivity())
id(device).set_brightness(x);
name: Inactive screen brightness
min_value: 0
max_value: 100
step: 5
initial_value: 60
restore_value: true
set_action:
- lambda: |-
if (id(deck).get_inactivity())
output:
- platform: ledc
pin: 10
- platform: ledc
pin: GPIO13
light:
- platform: monochromatic
output: out_10
- platform: status_led
name: "SC01 Plus 1 Blue LED"
pin: GPIO11
hd_device_sc01_plus:
brightness: 75
ha_deck:
main_screen: ${SCREEN_MAIN}
inactivity:
period: 60 # seconds dummy_temperature_sensor sensor.meteobridge_air_temperature
blank_screen: false
on_inactivity_change:
lambda: |-
if (x) {
id(device).set_brightness(id(inactive_screen_brightness).state);
} else {
id(device).set_brightness(id(screen_brightness).state);
screens:
- name: ${SCREEN_MAIN}
widgets:
- type: value-card
position: 8, 8
dimensions: 228x96
text: "Lincoln (New Zealand)"
enabled: return true;
on_click:
- logger.log: "Time clicked"
- logger.log:
format: "The heatpump mode is: %s"
args: [ 'id(heatpump_mode_sensor).state.c_str()' ]
- light.turn_on:
- lambda: |-
id(deck).switch_screen("$SCREEN_SOLAR");
- delay: 2s
- light.turn_off:
- type: value-card
position: 126, 112
text: Inside
icon:
unit: °C
value: |-
sprintf(buff, "%.1f", (id(sc01_1_temp).state) - 1.0);
return std::string(buff);
- type: value-card
position: 8, 112
text: Outside
icon:
unit: °C
value: |-
sprintf(buff, "%.1f", id(outside_temperature_sensor).state);
- type: value-card
position: 126, 216
text: Target
icon:
unit: °C
value: |-
sprintf(buff, "%.1f", id(heatpump_target_temperature_sensor).state);
#### heat_pump_target_temperature
- type: button
position: 244, 8
text: Set 16
icon:
# toggle: true
# checked: |-
# return id(dummy_light).current_values.is_on();
on_click:
then:
- homeassistant.service:
service: script.set_heat_pump_16
on_long_press:
- logger.log: "Set 16 long pressed"
- light.turn_on:
brightness: 50%
- delay: 2s
- light.turn_off:
- type: button
position: 362, 8
text: Set 23
icon:
# toggle: true
# checked: |-
on_click:
then:
service: script.set_heat_pump_23
on_long_press:
- logger.log: "Set 23 long pressed"
- type: value-card
position: 244, 112
text: Currently
value: |-
sprintf(buff, "%s", id(heatpump_mode_sensor).state.c_str());
- type: value-card
position: 362, 112
text: State
value: |-
sprintf(buff, "%s", id(heatpump_status).state.c_str());
#### select.heat_pump_hvac
- type: button
position: 244, 216
text: Mode
icon:
# toggle: true
on_click:
then:
service: script.heat_pump_mode_toggle
on_long_press:
- logger.log: "Mode toggle long pressed"
#### switch.heat_pump_power
- type: button
position: 362, 216
text: POWER
icon:
on_click:
then:
- light.turn_on:
service: switch.toggle
entity_id: switch.heat_pump_power
- delay: 2s
- light.turn_off:
on_long_press:
- logger.log: "Power long pressed"
# on_turn_on:
# - homeassistant.service:
# service: switch.toggle
# data:
# entity_id: switch.heat_pump_power
# on_turn_off:
# data:
- type: button
position: 8, 216
text: Brightness
icon:
on_click:
lambda: id(deck).switch_screen("$SCREEN_LED");
on_long_press:
- logger.log: "Brightness Button Long Pressed"
- light.turn_on:
brightness: 50%
- lambda: |-
id(deck).switch_screen("$SCREEN_LIGHTS");
- delay: 2s
- light.turn_off:
- name: ${SCREEN_ROOMS}
widgets:
- type: button
position: 8, 8
icon:
enabled: |-
return true;
on_click:
then:
- lambda: |-
id(deck).switch_screen("$SCREEN_MAIN");
- type: button
position: 126, 8
text: "Living Room"
icon:
enabled: |-
return true;
on_click:
then:
- lambda: |-
- type: button
position: 244, 8
text: "Main Bedroom"
icon:
enabled: |-
return true;
on_click:
then:
- lambda: |-
- type: button
position: 362, 8
text: "Kids Bedroom"
icon:
enabled: |-
return true;
on_click:
then:
- lambda: |-
- type: button
position: 8, 112
text: "Kitchen"
icon:
enabled: |-
return true;
on_click:
then:
- lambda: |-
- type: button
position: 126, 112
text: "Bathroom"
icon:
enabled: |-
return true;
on_click:
then:
- lambda: |-
- type: button
position: 244, 112
text: "Toilet"
icon:
enabled: |-
return true;
on_click:
then:
- lambda: |-
- type: button
position: 362, 112
text: "Corridor"
icon:
enabled: |-
return true;
on_click:
then:
- lambda: |-
- type: button
position: 8, 216
text: "Hallway"
icon:
enabled: |-
return true;
on_click:
then:
- lambda: |-
- name: ${SCREEN_LED}
widgets:
- type: button
position: 0, 0
dimensions: 48x320
icon:
on_click:
- lambda: id(deck).switch_screen("$SCREEN_MAIN");
- type: slider
position: 200, 8
dimensions: 100x304
text: Brightness
min: 0
max: 100
value: return id(device).get_brightness();
on_change:
lambda: id(device).set_brightness(x);
- name: ${SCREEN_LIGHTS}
widgets:
- type: button
position: 0, 0
dimensions: 48x320
icon:
on_click:
- type: button
position: 52, 4
dimensions: 104x100
text: Sofa Light
icon:
# toggle: true
on_click:
then:
- light.turn_on:
service: light.toggle
entity_id: light.light_main_notification_light
- delay: 2s
- light.turn_off:
on_long_press:
- logger.log: "Sofa Light long pressed"
- type: button
position: 52, 108
dimensions: 104x100
text: Table Light
icon:
# toggle: true
on_click:
then:
- light.turn_on:
entity_id: light.light_sewing_notification_light
- delay: 2s
- light.turn_off:
on_long_press:
- logger.log: "Table Light long pressed"
- name: ${SCREEN_SOLAR}
widgets:
- type: button
position: 0, 0
dimensions: 48x320
icon:
on_click:
################################################################# 8 accross
- type: value-card
position: 8, 4
dimensions: 104x56
text: "Solar"
icon:
- type: value-card
position: 8, 68
dimensions: 104x56
text: "North Solar"
- type: value-card
position: 8, 136
dimensions: 104x56
text: "South Solar"
- type: value-card
position: 8, 204
dimensions: 104x56
text: "Total Solar"
- type: value-card
position: 8, 272
dimensions: 104x56
text: "GRID"
icon:
######################################################################### next 128 accross
- type: value-card
position: 128, 4
dimensions: 104x56
text: Phase 1
icon:
- type: value-card
position: 128, 68
dimensions: 104x56
# text: North
# icon:
value: |-
sprintf(buff, "%.1f", id(modbus_phase_1_current_watts).state);
- type: value-card
position: 128, 136
dimensions: 104x56
# text: South
# icon:
value: |-
sprintf(buff, "%.1f", id(modbus_fronius_phase_1_current_watts).state);
- type: value-card
position: 128, 204
dimensions: 104x56
# text: Total
# icon:
value: |-
sprintf(buff, "%.1f", id(p_1_total_solar_power).state);
- type: value-card
position: 128, 272
dimensions: 104x56
# text: Grid
# icon:
value: |-
sprintf(buff, "%.1f", id(p_p1).state);
######################################################################### next 248 accross
- type: value-card
position: 248, 4
dimensions: 104x56
text: Phase 2
icon:
- type: value-card
position: 248, 68
dimensions: 104x56
# text: North
# icon:
value: |-
sprintf(buff, "%.1f", id(modbus_phase_2_current_watts).state);
- type: value-card
position: 248, 136
dimensions: 104x56
# text: South
# icon:
value: |-
sprintf(buff, "%.1f", id(modbus_fronius_phase_2_current_watts).state);
- type: value-card
position: 248, 204
dimensions: 104x56
# text: Total
# icon:
value: |-
sprintf(buff, "%.1f", id(p_2_total_solar_power).state);
- type: value-card
position: 248, 272
dimensions: 104x56
# text: Grid
# icon:
value: |-
sprintf(buff, "%.1f", id(p_2).state);
######################################################################### next 368 accross
- type: value-card
position: 368, 4
dimensions: 104x56
text: Phase 3
icon:
- type: value-card
position: 368, 68
dimensions: 104x56
# text: North
# icon:
value: |-
sprintf(buff, "%.1f", id(modbus_phase_3_current_watts).state);
- type: value-card
position: 368, 136
dimensions: 104x56
text: --
# icon:
- type: value-card
position: 368, 204
dimensions: 104x56
# text: Total
# icon:
value: |-
sprintf(buff, "%.1f", id(p_3_total_solar_power).state);
- type: value-card
position: 368, 272
dimensions: 104x56
# text: Grid
# icon:
value: |-
sprintf(buff, "%.1f", id(p_3).state);
