WT32-SC01 with esphome
I have one of these screens and I know openHasp is better for it but I need to use this device with esphome so I can also enable it as a BT proxy.
Does anyone know what display it uses or which one to select when writing the esphome config yaml?
I’ve got one, as well. I would love to be able to set it up as a wall thermostat. Basically just a BME-280 to report the climate data, and the screen to do basic temperature display and adjustments, plus mode controls
I vote for this also. I have one of these, and it’s a nice single-board esp32 and display.
Works very nice with the recommended software, but it would be awesome to incorporate it with ESP-Home and Home Assistant.
Any updates on this? Trying to decide between the WT32-SC01 and an M5Stack Core2
Highly unlikely you can use a screen and a BT proxy
Not enough memory, tried a few esp32s and ili9341 and no go.
The wt32-sc01 does not have a native integration in esphome either, some “guy” wrote some code for it and put it behind a pay wall, super community friendly
Are you able to share the link to that please?
Not that I intent to purchase it, but curious to know what they’ve done.
I did find this, but haven’t tried it yet: jhogendorn/esphome-wt32-sc01-display: A custom esphome component to support the wt32-sc01 display (github.com)
Disregard, found the link.
I did however find this: 3.5" 320x480 WT32-SC01 | OXRS Docs
They use the ESP web flasher to deploy it, so there’s hope. Unfortunately the site doesn’t seem to explain how to install their main system, so I’m going to see if I can pick it apart.
The WT32-SC01 device is now supported with the ILI9xxx driver in the 2023.3.1 ESPHome build
Awesome!
What “model:” should we use to define it on the YAML?
Is there any documentation or examples to get started?
this works for me. have not played with touch yet.
esp32:
board: esp-wrover-kit
framework:
type: arduino
output:
  • platform: gpio
    pin: GPIO23
Which pins are you using to interface the display? In ESPHome there is information about using cs/dc/reset pins, but the panel seems to be using a whole set of other data pins from the documentation.
Trying to map this…
reset_pin -> LCD_RESET = GPIO4
cs_pin -> LCD_RS (Command/Data selection) = GPIO0
dc_pin -> LCDWR (Write clock) = GPIO47
?? -> LCD_TE (Frame sync) = GPIO48
MOSI/CLK pins?
Could someone be kind to post the full YAML configuration?
not giving full YAML, but here are the important parts that should get you going…
esp32:
  framework:
    type: arduino
output:
  - platform: gpio
    pin: GPIO23
light:
  - platform: binary
    name: "wt32 Back Light"
    output: tst_Backlight
    restore_mode: ALWAYS_ON
spi:
  clk_pin: GPIO14
  mosi_pin: GPIO13
  miso_pin: GPIO12
display:
  - platform: ili9xxx
    model: ST7796
    cs_pin: GPIO15
    dc_pin: GPIO21
    reset_pin: GPIO22
    rotation: 270
hth
Awesome, thanks!
Will give it a shot.
That worked a treat, thank you!
Here’s my with code to at least display some text.
Next step is to start playing with touch.
substitutions:
  friendly_name: "WT32-SC01"
  id_prefix: "wt32_sc01"
esphome:
esp32:
  framework:
    type: arduino
packages:
  device_base: !include includes/common_settings.yaml
#esp32_ble_tracker:
#bluetooth_proxy:
#    active: true
time:
  - platform: homeassistant
output:
  - platform: gpio
    pin: GPIO23
light:
  - platform: binary
    name: "${friendly_name} Back Light"
spi:
  clk_pin: GPIO14
  mosi_pin: GPIO13
  miso_pin: GPIO12
display:
  - platform: ili9xxx
    model: ST7796
    cs_pin: GPIO15
    dc_pin: GPIO21
    reset_pin: GPIO22
    rotation: 270
    pages:
      - id: page1
        lambda: |-
          it.printf(64,0, id(my_font), TextAlign::TOP_CENTER, "WT32-SC01");
          it.strftime(64, 40, id(my_font), TextAlign::BASELINE_CENTER, "%I:%M:%S %p", id(homeassistant_time).now());
          it.printf(64, 60, id(my_font), TextAlign::BOTTOM_CENTER, "Time");
      - id: page2
        lambda: |-
          it.printf(64, 40, id(my_font), TextAlign::BASELINE_CENTER, "Hello Loryan!");
          it.printf(64, 60, id(my_font), TextAlign::BOTTOM_CENTER, "Hi from down here");
font:
  - file:
      type: gfonts
      family: "Open Sans"
color:
  - id: my_red
    red: 100%
    green: 3%
    blue: 5%
  - id: my_white
    red: 100%
    green: 100%
    blue: 100%
interval:
  - interval: 5s
    then:
      - display.page.show_next: wt32_sc01_display
      - component.update: wt32_sc01_display
@DeLorean,
I’ve same board and no problems to manage text and image on the display,
but no success with the touchscreen…
I’ve tried different configuration, related FT6236, without any good results…
Do you have some news, or some suggestion, to enable the touchscreen function on WT32-SC01 ???
Thanks in advance for any help !
I’ve struggled a bit with getting an image on screen. I was able to get it on, but not an animated GIF.
I haven’t been able to get the touch going natively with ESPHome unfortunately, unless I used openHASP - but then that just introduced considerably more stuff I had to learn and make work. :frowning:
Same experience, jerky anigif and touch going nowhere !
I also migrated to openHasp, it’s definitely easier and more effective,
but I have problems with the openHasp integration in HACS under HA.
Sometime it’s not loaded, I’m working on it.
I’m brand new to esphome and wt32-sc01
  1. thanks for having shared your informations, I’ve ended to get a first successful deployment in a few minutes.
  2. regarding touchescreen, I found two informations, that may help:
Touch (FT6336U)
    TOUCH_SDA=18
    TOUCH_SCL=19
    I2C_TOUCH_ADDRESS=0x38
so not tested so far, but this could be a good starting point:
external_components:
  - source: github://gpambrozio/esphome@FT6336U-touch
    components: [ ft63x6 ]
i2c:
  sda: 18
  scl: 19
  scan: false
touchscreen:
  - platform: ft63x6
    i2c_id: i2c_bus_intern
    on_touch:
      - logger.log:
          format: Touch at (%d, %d)
          args: [touch.x, touch.y]
UPDATE: finally compiled, tested and it looks not bad
when I touch the screen, I get activity:
Very interesting, I’ll give it a try as soon as I have time !
Now I using the WT32 with OpenHasp and it works fine.
Thanks for the useful information!
