good morning, i have a beca thermostat where i flasher the wtermostatbeca firmware. using the mqtt protocol inserted it on home assistant. I would like to create a script that reads when the thermostat closes the heating relay. Which command can I use?
What is the entity_id of the relay and how do you want to be notified when the relay is on?
Just a graph or sensor display in the front end, or a notification message, or a statistics sensor that tells you how long the relay has been on today?
Unfortunately I can’t access github where I am at the moment.
Go to the developer tools states menu, look for your climate entity and copy its attributes here. If you are going to use a screenshot, please make it small. I’m on a very slow satellite link.
Yes but unfortunately the Lovelace History graph only graphs entities, not entity attributes. Usually the way around this is to create a template sensor from the attribute and graph that.
However, the climate entity is a special case. If you create a Lovelace history graph and specify the climate entity as the thing to graph it will show: the set temperature, the current temperature and the times the thermostat is on.
Actually, now I think about it, that may only be in the more-info pop-up for the climate entity. I’m not sure - try it and see. If it does not show the active times on the graph we can go down the template sensor path.
OK, I will try. I ask you for another help. i am trying to integrate imou camera movements. i used onvif to visualize it but how could i manage the movements?
