WTH - Ability to join entity id history together if something went wrong (e.g. _2 entities)
Sometimes when an integration fails, you make an unseen mistake or some update is a little bit wonky, a _2 entity is created or completely new entities for the same piece of information, which means your history is getting split up for a certain period of time over two entity ids for the same entity. It would be quite useful if we’d be able to combine these datapoints. (maybe even if there are no overlaps between the 2 entity ids, both for new or historic data if it happened before and there is a lot of split recorded data.)
