Implementing AI into Home Assistant will reduce the learning curve for new users. After exposing all the devices and entities that are automatically discovered, the system will recommend automation based on the user interaction with the devices and sensors. For example, if you have a smart bulb and a presence detector and the user turns off the bulb and then exits the room so the presence detector stops detecting presence, it will suggest to the user an automation to control the lights with the presence sensor.
Duplicate of https://community.home-assistant.io/t/wth-cant-i-create-an-automation-using-a-word-discription-and-a-llm/803696
Closed. Please vote and comment on the WTH linked above.
Please search before posting a new WTH.
