WTH Almost Everything is Related - improve navigation, connect entities and devices
Using HA via Frontend is an awesome experience, in which we design and use a nice looking lovelace UI with carefully crafted and placed controls.
Whenever I open a more info dialog on an entity I always lack the possibility to navigate to other related entities. In the rare case the integration connects the entity it works, but mostly many of my “things” do not relate - at least this relation is not seen by HA.
I think it would be awesome to have the ability to
  • Manually specify for each entity/device related entities/devices
    (e.g. connect an IR blaster with a TV media_player)
  • display related_entities based on existing config connections
    (e.g. generic_thermostat<->target_sensor, utility_meter, derivative<->source, template sensor<->trigger) and so forth. The data is clearly available easily in HA core.
This would improve the navigation and connected-experience of HA.
