Why can’t blueprints define a pattern that can be used to suggest its use?
For example, detecting a TV, lights, and a mmwave sensor in the same room could trigger the suggestion of an automation that pauses your TV and turns on the lights when you start moving across the room.
The suggestion engine could run whenever a new entity is added, or the attribute of an entity (name, labels, area, etc.) are changed.
