WTH Battery Device Alerts and Replacement Tracking
Hi everyone,
I’d like to suggest a feature enhancement for battery-powered devices in Home Assistant to make battery management more intuitive and user-friendly.
Proposed Features:
  1. Automatic Low Battery Alerts:
    • Home Assistant could send automatic notifications when a device’s battery level drops below a user-defined threshold (e.g., 20%).
    • Notifications could include reminders for critical devices (e.g., sensors, locks, or thermostats).
  2. Battery Replacement Indicator:
    • Introduce an option to mark when a battery has been replaced for a specific device.
    • Users could log the replacement manually via the device settings in the UI
  3. Replacement Tracking and Reminders:
    • Home Assistant could track the last battery replacement date and display it in the entity details.
    • Optionally, set up reminders for expected replacement intervals based on typical battery lifespans.
    • Example: “Last replaced 6 months ago. Expected lifespan: 12 months.”
  4. Battery Health Overview:
    • A dashboard card or report summarizing battery levels across all devices.
    • Highlight critical devices with low battery levels or long replacement times.
Benefits:
  • Avoids unexpected downtime for critical devices.
  • Provides peace of mind by tracking battery health across the entire smart home.
  • Simplifies battery maintenance and replacement scheduling.
Would this be a useful addition for others? Any thoughts or suggestions to refine the idea?
  1. This is currently possible with an automation. Check out this blueprint.
  2. Currently devices with batteries show their battery percent on the top of the device page. Having a battery level as a repair alert is a good idea, though. You can currently do this with Spook, but it is not in core.
  3. This sounds a lot like an automation you could make. Perhaps add a label to your device that contains the replacement date and use a battery percentage trigger to run your automation and make a notification.
  4. This seems possible with the current UI cards. Add an Entity Card for the battery level and make its visibility conditioned upon the battery level being below a certain threshold.
Have a look at the Battery Notes integration.
https://andrew-codechimp.github.io/HA-Battery-Notes/
Check out Home Keeper: GitHub - prestomation/ha-home-keeper: Home Keeper is a Home Assistant plugin for tracking home maintenance and chores with deep HA integration · GitHub — built this because I wanted to keep the actual replacement history for batteries, with a dashboard overview of everything at a glance. Pairs great with Battery Notes for the low-battery alert side, if you add my 'glue' integration you'll get tasks automatically created by battery notes that include which kind of battery you need.
