After HA updates the front end typically after a short while (but not immediately) to informl me there is an update and click on the reload button. Why can’t it do it for me such as;
a check box or option that will automatically reload it on future updates without interaction (per web browser/session?)
An indication after x seconds it will automatically reload
You mean refreshing the cache? Like ctrl+f5? I’m assuming it isn’t as straight forward as you’re assuming, otherwise it would be implemented already. Or possibly because it is such a minimal thing, no one has thought to implement it.
Is it really a sore point for you to refresh your open dashboard tabs after a frontend component update?
I was wondering if it tells me I need to click on the reload button that appears why it doesn’t do itself? When you have multiple devices it’s just one more thing to do when updating is to do the update on each. If there’s a browser mod does that imply that it could do it technically without anything client side?
What happens on desktop when you have X tabs open to your dashboard? Or any tab open to Hass? How will it know which tabs to actually refresh? What if one of those tabs is open on an automation that you’re working on and haven’t saved? Or editing dashboards, etc.
That is an example of things to consider besides just 1 use case. As another poster pointed out, you can setup automations to remedy your use case.
I have never seen this, at least not directly, when updating Home Assistant itself. I have seen this in HACS Lovelace UI cards when updating them. And the reason is simple; the web browser will look to the cache first and continue using the old version unless you force it to refresh.
