I am specifically keeping 3rd parties out of my smart home, but I can’t set up Matter devices on iOS or Android without the setup involving Apple or Google’s platform services.
I want to be able to trigger the HA native setup flow from a phone without engaging the platform services on my mobile device. Instead, I’m stuck manually entering codes into the web UI from my laptop.
You can commission via the matterJS server or HA matter settings if you have ESPhome with Bluetooth proxy. It is not well documented but some kind of workaround.
Yeah, I mentioned using that workaround, but it’s not a great one; I have to type in long, hard to read codes manually, and they have to be re-entered if the page reloads, etc.
I want to be able to capture the QR code from my device using the companion app, but not use the google/apple stack for onboarding, and instead have it use my BT proxies.
