WTH - Can't define recorder sampling by entity type
There is currently no way to reduce the amount of data into the database by setting different sampling by entity type.
For example the temperature can be stored only each 5 min where the instantaneous power have to be recorded as fast as possible.
For me there are 3 types of data sampling
  • low rate (typically more than a min) : temperature, humidity, pressure…
  • fast rate (typically some seconds) : instantaneous power, …
  • based on events : door opening, button switch,…
That is similar to my suggestion, to have something like filter integration in entity customization.
