It should be easy to configure the color of the state / name / icon based on conditions through the Lovelace UI.
- Ex: if power usage is over 7000w turn the entity icon and state to red.
This makes it easy for users to see if there is something that needs their attention just by glancing at their dashboard.
Right now I have to bust out yaml and Customize global config …and then install an addon just to make this work. Like the whole point of the dashboard is for you to see things that need your attention
