I have multiple thermostats to control baseboard heaters in one area and I want them to all behave as controls to a single logical climate entity, including a control in the HA interface. More than 1 state/attribute needs to be synchronized as they each have a set temperature and operating mode.
I’ve tried multiple solutions but all have failed over time:
- Grouping them doesn’t produce the level of synchronization (>1 state/attribute) required and shows averaging of the set temperature from the thermostats
- Automation triggered off of state/attribute change is overly complex with conditions and causes inadvertent loops as each synchronized thermostat kicks off another sync loop
- A community add-on worked for a bit but broke when the thermostat entities were updated and it never worked the same again
Why doesn’t grouping entities provide synchronization options? I want to be able to indicate that entities should be synchronized, which state/attribute(s) should be synchronized, and what strategy to use to handle a de-sync situation.
This last de-sync situation happens sometimes with a simple 2 entity automation-based synchronization I created for a disconnected light switch and group of lights. I always want their state to reflect each other so when 1 turns on/off the other does and vice versa. Every now and again though they get out of sync and 1 of my family members will get frustrated trying to turn on the lights but can’t because the switch is already on. A proper group synchronization solution with re-sync strategies would help with this.
