WTH can't I move an event to another calendar?
I use quite a free different calendars to organize stuff (and run automations based on which calendar have the event). Sometimes, I create an event in the wrong calendar, and currently it’s not easy to move an entry to another calendar.
Not easy means, you have to delete the entry in one calendar and recreate it in the other one.
Perhaps you can use the developer tools to extract the entry and then create it with the same data in another calendar, but it’s not “easy” in any case…
  • If you do it often then a script would come in handy.
One that takes three parameters.
  • Calendar event
  • Source Calendar
  • Destination Calendar
Start off simple, then start dealing with the complexities as you progress.
  • Does the event already exist in the destination Calendar?
  • Did it get added successfully?
  • Did it delete from the source Calendar successfully?
  • Etc.
