Why is there no navigation/route option available in HA?
(I don’t know if leaflet supports this)
This weekend I wanted to navigate to my wife who was somewhere in the city.
so I opened HA to check her location, but then I couldn’t simply click “navigate to”
For somehow I needed to check the map of open up another app for navigation.
It would be welcome if there is just such an option which updates the destination if the person moves.
If you click on her person instead of the map it will show her location in the more-info page, zoomed in. You can also make a map card that just shows her and it will always be centered on her.
TLDR: Go from her person, not the map. The map will always show you the zones you have configured.
Directions can only be provided by an integration that provides them, which aren’t available by default. And google for example, costs money. This is something you’ll have to add yourself, which is pretty easy to do. It still won’t draw the directions on the map because these apis don’t have that information available.
This is brilliant! I’ve just used this to create a “Directions To Work” button.
I already get a mobile notification with a traffic map snapshot if my expected commute time is greater than normal or I am not at home which already has an action that just opens the google maps app to my current location. I’ve added an action to press this button so it will open best route and directions to work at the click of a button!
This is the method I’ve used reliably in the past. Seemingly with android 15 or whatever the latest is though this only works in foreground and not when the phone is locked. Does anyone have any workarounds for this? Interestingly, even if I run this script from android auto it fails BUT when going through android auto → Navigation → User it is successfully able to launch google maps and make the direction to that person. So I presume there’s potentially some way to trigger this from an automation given it seems the companion app via android_auto has this privilege?
the intents worked beautifully,
Unfortunately with the android 15 update on my S24 Ultra it no longer works with a locked phone.
However, what I did find is that the intent does get send, waze does open, it just doesn’t start the navigation.
I found below “car_ui: true” to have the notification appear in android auto, I hope that this might be the solution to the navigation no longer working.
