I have this issue also on desktop. Values are missing. In browser, couple of CTRL+R will fix this, but on companion app there is no way to force refresh. Started to happen about 2-3 releases back. It happens about 50% of the time, can not post desktop screenshot now, because it works there atm.
Yes there is.
Do you have an Apple or Android phone?
I have Android phone.
See this post: https://community.home-assistant.io/t/1-camera-on-1-device-not-working-works-on-all-other-devices-perfectly/788294/4?u=tom_l
Thank you for the explanation, but this had not solved the problem.
And this is not one time thing anyway, it happens to me all the time, so it is certainly a bug.
These values are SVGs which are supposed to be rescaled when a card is changed.
So, suggest you to create a topic in Configuration-Frontend since this is not a “WTH”, it could be a bug.
(meanwhile - test on a desktop with a standard theme on a masonry-layout view)
I can see the graphics well, I don’t see the number values, which should be font, not SVG. I also use standard black theme and masonry.
I think it is bug and I wonder why others don’t report this, because I would expect many people to be affected. But maybe it is related to something in my setup. I however don’t use many special things.
I did not bring myself to report this as a bug, simply because I had reported issues twice before (frontend team) and they were largely ignored so I am struggling to find the will to spend time on this. But maybe I give it a try once more.
May be; and resizing a font could be also successful.
Currently using SVG causes this issue.
