Specifically the radius cannot be edited in the GUI. It appears that lat/lon can be changed by moving the home icon. (Clarify that overriding Home in UI is not supported by koying · Pull Request #19354 · home-assistant/home-assistant.io · GitHub)
There was some reasoning behind this. I can’t remember what it was. Still would like to have the option to alter this from the UI though, good wth.
I also miss the possibility to enter the longitude and latitude for the location of the house in the edit field. Accessibility (WCAG) is an additional argument. Currently, it is not possible to set the home location from the GUI with a screen reader.
Yeah, I’m moving soon and thought this should be easier!
I can’t figure it out. Where should I go to update home location then?
Edit: Must do it old way via yaml
Or you can forget about the yaml, and drag and drop your home icon directly in the map / zone view of the HAOS UI.
Unfortunately, the option of dragging the house location on the map is an accessibility barrier. Using the NVDA screen reader, no one can do that. And 2 small edit fields (latitude and longitude) are enough. Today it is, it’s an accessibility bug and something for urgent improvement.
