WTH can't we delay an automation per triggering entity?
coming from this thread:
since we now can end an action block with
 - delay: 60
to prevent an automation from triggering within that timeframe, it would be very nice if we could do that also for automations with more than 1 triggering trigger in the trigger block (not trying to be funny here, sorry)
example:
 - alias: Daughters presence
    initial_state: false
      platform: state
      entity_id:
        - group.daughter_1
        - group.daughter_2
        - device_tracker.daughter_3
        - device_tracker.daughter_4
    condition:
      - condition: state
        entity_id: input_boolean.notify_presence
        state: 'on'
#      - condition: template
#        value_template: >
#          {{is_state('input_boolean.notify_presence','on')}}
        value_template: >
          {{trigger.to_state is not none and
            trigger.from_state is not none and
            trigger.to_state.state in ['home','not_home'] and
            trigger.to_state.state != trigger.from_state.state}}
        value_template: >
          {% set last = trigger.from_state.last_changed %}
          {{last is none or (now() - last).total_seconds() > 120}}
#          {{(now() - trigger.from_state.last_changed).total_seconds() > 120}}
      service: notify.notify
      data_template:
        title: >
          Daughter {{'arrived at' if is_state(trigger.entity_id,'home') else 'left'}} home
        message: >-
          {{as_timestamp(now())|timestamp_custom('%X')}}
          {{trigger.to_state.name}} {{'arrived at' if is_state(trigger.to_state,'home') else 'left'}} home.
still needs the condition:
        value_template: >
because the delay at the end would prevent multiple executions from multiple triggers.
introducing a new delay per trigger would solve that. Ive called it trigger_delay in the linked post, but that was flagged by Phil :wink: Not really important what its named, as long as we can use a delay_per_trigger.
thanks!
coming to think of it: maybe we don’t even need a new delay, but simply have the delay respect multiple triggers? So it all happens in the backend?
