I have multiple awnings that are grouped together. Even though they are from the same manufacturer, one awning has a different direction for open and close. Unfortunately, the motor does not have an option to invert the direction (confirmed with Somfy). The only solution is to create a custom cover template for the affected awning with an inverted direction, so it aligns with the others in the group.
I would expect a simple toggle in the entity settings (e.g., “Invert Direction: 0/1”).
