So I was wondering WTH we can’t “make” custom entities. As an example, I made myself an ESPHome device to control my split system air con. It can change the temp, fan speed, on/off status, heating/cooling mode etc using the ESP I made. However, I can’t use the thermostat card because it’s not a climate entity. Even though it does all the same things as a climate entity, it’s not one.
It would be great if we could make custom entities with custom properties. For example, we could say that for my custom thermostat, the temperature is given by my ESPHome sensor’s temperature reading. The function to change temperature is given by my ESPHome function etc. Once it’s all done, it makes an entity that can be used with cards. I know there’s the generic thermostat, but it’s specific to a thermostat, which I don’t have (i.e. it’s looking for a switch entity specifically in order to change the heating/cooling mode rather than an ESPHome function).
I ended up finding something through HACS that works as a generic climate entity, but it would be good to have this as part of HA natively for any entity that we want to map. It could even be a new type of helper called “Entity”, which we can then choose what entity we want to map
I have, but like I said, that’s a thermostat specifically. Since this is a split system air con, there’s no way to map all the features of my split system to the generic thermostat. Also the thermostat needs things like a temperature sensor for the room, which I don’t have. It also specifically needs a switch entity to turn the aircon/heater on/off when the target temperature is reached, which is an issue because for a split system there’s no target temperature, and there’s no need to physically turn it on/off when the temperature is reached since it handles that all automatically.
To be fair, what you are describing already exists* inside of HA. It’s called a template entity. There are many different types of entities you can create:
But also it seems the one thing that you are asking for (climate) isn’t provided for in the template entity schema. You should probably post a FR for a template climate entity.
climate:
- platform: midea
name: Klimatyzacja dol # Use a unique name.
period: 1s # Optional
timeout: 2s # Optional
num_attempts: 3 # Optional
autoconf: true # Autoconfigure most options.
beeper: false # Beep on commands.
visual: # Optional. Example of visual settings override.
min_temperature: 17 °C # min: 17
max_temperature: 30 °C # max: 30
temperature_step: 0.5 °C # min: 0.5
supported_modes: # All capabilities in this section detected by autoconf.
- FAN_ONLY # This capability is always used.
- HEAT_COOL
- COOL
- HEAT
- DRY
custom_fan_modes:
- SILENT
- TURBO
supported_presets: # All capabilities in this section detected by autoconf.
- ECO
- BOOST
- SLEEP # This capability is always used.
custom_presets: # All capabilities in this section detected by autoconf.
- FREEZE_PROTECTION
supported_swing_modes:
- VERTICAL # This capability is always used.
- HORIZONTAL
- BOTH
outdoor_temperature: # Optional. Outdoor temperature sensor (may display)
power_usage: # Optional. Power usage sensor (only for devices that support this feature).
humidity_setpoint: # Optional. Indoor humidity sensor (only for devices that support this feature).
It was a while ago I set up my ESPHome but from memory I wasn’t able to set up a climate and had to manually read and set up the various IR codes to make it work, but it was ages ago so I might be misremembering. As for the template, it does seem to do that for other entities, but I wonder if there’s any other entity types that might be worth adding in as well?
