WTH cover.set_tilt_position no longer reports status
I have venetian blinds that no longer report their tilt position because that value is no longer supported in Home Assistant.
I have Z-Wave powered iBlinds from MyiBlinds-dot-com. The company says it has been unable to contact anyone at HA to resolve the issue.
Please help.
It’s still supported. Is the device reporting it properly? It’s likely that it does not or the inclusion information missed it.
Here’s the code
It requires the window opening command class. It’s possible your device does not follow the standard and output that properly.
Thanks. I will pass this on to the company, MyiBlinds.
