I’m using celsius and kilograms, not fahrenheit and pounds. And incidentally i’m also used to 24 hour clock, not 12 hour clock. So WTH datetime input boolean helper is only available as 12 hours?
I’m using the date time input helper with 24 hours - I’m running 2022.10.x but it also worked for me at least since 2022.09.x
I could not find a 12/24 setting anywhere, so not sure what the difference is.
Your system units for time aren’t set properly. Click on your profile, select Time Format, and choose 24 hour. Or choose a language that uses a 24 hour clock.
