WTH do buttons/tiles for automations not run the automation by default
If I want to add a button on a dashboard to run an automation, I can select a button/tile and choose an automation as the entity. However, by default, the button will enable/disable the automation instead of running it - And setting the button up to actually run the automation is bothersome (set up to run an action → select the action to trigger an automation → find the correct automation, even though you already selected the automation when creating the tile. Repeat if you want the same action for tapping the symbol)
I can’t imagine enabling/disabling an automation is more common than triggering an automation. I think the default should be to trigger the automation when creating a new button/tile
Don’t forget to vote for your own WTH!
What you’re describing is a script. Which can be ran exactly like you’re asking.
