WTH does Energy Dashboard not support nesting energy sensors?
I just started using energy metering about a month ago and it has been amazingly useful. This is one issue that I think could be solved fairly easily.
Description:
I have CT clamps measuring many circuits in my home, including the entire garage. In the garage I have a car charger that provides energy metering. With this setup, electricity consumption when I charge my car is counted by both sensors. I would like HA to track both, but it needs to understand that the car charger is a sub-meter to the overall garage circuit meter. Currently, it simply double counts this consumption and calculates a negative ā€œUntracked consumptionā€.
Proposed solution:
The energy configuration of individual devices needs to have the notion of ā€œupstreamā€, or ā€œparentā€ device, so they can exist in a hierarchy. Then HA could properly calculate Untracked consumption by excluding downstream/child devices. In the individual device total usage bar graphs, the downstream devices should be included together within its upstream device.
Why not make a template entity that just subtracts the other consumption of the car from the garage?
@martinhill I added a vote for ya’ because I think the intent of what you’re after is spot on. Emporia does this nesting very well with their native app. For HA to do energy properly, a feature like this is fundamental and would be much better than template sensors everywhere. That’s what I currently have and it ends up compounding the already horrible issues for energy sensors which may or may not zeroize at midnight every day.
Maybe consider changing the title to ā€œWTH does HA not support nesting energy sensorsā€ or similar?
Yes, that would be very nice feature - of course you can do that with templates as a workaround and it might be fine for 1 device but what if you have more of them then it just becomes difficult to manage
The way we can design the sensor to be used in the Energy Dashboard could be enhanced and probably more user friendly.
I am not very advanced in HA, not a newbie either but I could not figure out how to build proper calculated sensor using template.
I keep having negative values which is impossible theoritically.
… because it’s ineficcient in many way.
  • might be a huge task for maintainer, depending on growing number of power devices
  • contributes to system load
  • such substracting sensors are just template sensors which cannot be linked with devices…
Let me paraphrase your question: why just not make it easier and strightforward?
Why you suggesting workarounds on WTH problem?
I already have a few substracting sensors (for different reasons) so I know how confusing it can be sometimes.
I agree with OP. It would be very usefulll to put on dashboard any power measurement sensor while only the most parent ones will be taken for overal calculation.
I guess it was not a problem before untracked consumption was added.
I offer work arounds because many WTHs will not be acted on. This current functionality is in the frontend, I don’t see how the info can be published back to the backed to generate an entity. It would likely need to come from a user managed integration like utility meter or something new. I.e. no different than making a template entity in a way.
This gets untenable in large energy monitoring P.
Ive tried. And stopped trying it’s too hard.
Ive got about 50 circuits I the home in a complex distribution system. I’ve got sensors to measured at various levels. I’ve got incoming service all the breakers all the lugs and one breaker box is even fed by the other and nests at that level. So I start with most of my loads at least one maybe two levels of nesting down. Unless I cherry pick my sensors my energy dashboard is trash because it wants to double and triple and sometimes I’m even getting quadruple counts.
I can accommodate it nicely with something like a Sankey chart (see above and that’s what a space heater does to electricity consumption btw) but the base energy dashboard is only good for top level rollups right now because I have to omit a lot or build a ton of templates by hand
Id TOTALLY support rollups.
And yes it was the untracked feature that did it.
I’m not against this WTH, I just don’t see how it could be implemented with the current system for the energy panel. That’s the only reason I’m offering the work around as a method to get the desired result.
Oh i get you. And agree. I’m for creating templates when necessary but no I’m not building… Last count was 55 templates to do that. I chose to display only the rollups and use the sankey for detail.
Unfortunately it means the energy panel needs a complete rework to handle complex deployment. And that rework needs some method that can define nesting. (prob a parent/child attribute in a monitored entiity that if exists… Etc.)
Exactly! Between @NicoLeOca’s issue with negative energy sensor values (most likely means they need to screw with the energy sensors’ state_class and/or create utility meters to use in their place*) and this WTH where HA needs a mechanism to understand the hierarchy of these circuits, creating a usable picture of energy usage can be very cumbersome. Plus, some users may be ok with a simple circuit presentation, but I’d rather view my energy in a logical waterfall.
Energy Sources > Energy Source Categories > Grid/Mains > Areas > Floors > Rooms > Devices
A daunting programming task to capture all of these issues and present an approachable UX for sure, but I think that’s what is really needed to make the energy dashboard truly useful.
*This whole situation should probably be a WTH too. As in…WTH can’t HA filter out large energy sensor spikes at midnight every day?
Same mindset, different target
I was trying to view my energy usage by device type.
Entertainment; Cooking; Heating System, Lighting; specific appliances…
I could think of making use of labels for the energy dashboard…
It seems like measuring power through breaker clamps and smart plugs is a VERY common use-case… or nested smart plugs. I have a small apartment and over 20 smart plugs plus clamps on my breaker box. From a use-case perspective it’s wild that this wasn’t considered as basic functionality for the Energy panel.
I won’t pretend to know how the front-end interfaces with the back-end but it seems so easy to just make SOME sort of hierarchy in the front-end and have it subtract the upstream totals. Perhaps this interface could just auto-generate and manage the template sensors mentioned above… but I agree with the people who point out that with even a moderately sized group of smart plugs doing this manually becomes untenable.
And I feel like between areas and labels you could get a pretty good understanding of different types of usage, but fundamentally in order to have an understanding of energy usage you need to know where the power comes from and where it’s going. That’s a logical representation of the PHYSICAL electrical connections. With this you can even get an understanfding of internal losses and some fault types.
About the mention of frontend ↔ backend propagation, it’s not about new entities but accurately displaying usage of individual devices in energy dashboard thus frontend only (in this case).
Stitching it up using template sensors on top of energy sensors is not that straight forward as subtracting values. You have to create whole suit of sensors (including utility meters) and that’s really tedious job for such a simple thing (even so the implementation in the dashboard won’t be easy at all, hah).
You can vote for Energy dashboard - Nesting (multilevel) of Individual devices - Feature Requests - Home Assistant Community too :wink:
A feature to enable nested energy sensors has been merged for 2025.4 release.
For now it will only be used to correct information in the individual devices detail graph.
Complicated config for the fringe use case… Fine. Just happy it’s going in. :sunglasses:
Why only electric power meters have ability to nest?
I have also water meters that are nested.
In my country a the typical solution from water supply companies is to install additional sub counter for garden. Then we don’t pay for sewage disposal of the amount of water we use to garden.
Please add hierarchy to water meters.
Because adding each feature takes effort, and a lot of people asked for nested energy sensors, and not a lot of people asked for nested water meters.
If you have a need for a feature that isn’t covered, please make a feature request post so the demand can be gauged.
I found this request 1 year old in GitHub, to improve water meters in Energy dashboard.
How we can make this topic more observable?
