WTH does my HomeKit thermostat card get out of sync with my thermostat?
I have my ecobee Premium Thermostat integrated with HA via Homekit.
I have an automation that runs the fan on my furnace for 10 minutes if it’s been more than an hour without running. When it turns off the fan, it also does a “clear hold” button press so the thermostat isn’t left in a “temporary hold” state.
If I manually change the temperature of my thermostat via the HA thermostat card, when the above automation runs, it resets the temperature back to the scheduled temperature as expected since the clear hold button was pressed. However, the set temperature in the thermostat card still shows the earlier manually set temperature.
Since I’m doing all this in HA, I’d expect the thermostat card to update to the correct temperature also. This feels like an edge case, but wanted to share since I don’t typically file bugs.
